Eastcoast521 Posted July 7, 2010 Report Share Posted July 7, 2010 I've seen plenty of discussion on this topic but don't recall hearing anyone ask if a matchbox distributor from a 6 cylinder l-series engine would work if you put in/on the 4 cylinder cap and rotor. Would that work? Quote Link to comment
zerow Posted July 7, 2010 Report Share Posted July 7, 2010 I've seen plenty of discussion on this topic but don't recall hearing anyone ask if a matchbox distributor from a 6 cylinder l-series engine would work if you put in/on the 4 cylinder cap and rotor. Would that work? Negative and No. If you pull the distributor cap on the 6 cylinder EI distributor, you will see on the stator that there are 6 prongs. This is the setup for the 6 cylinder cars. The 4 cylinder cars have a 4 prong stator. Now, I cannot be the one to confirm or deny this, but, I have heard that the stators can be purchased from Nissan, along with the 4 prong assembly that goes on to the distributor shaft. With the reliability of the EI distributor, and the cost of buying two VERY expensive parts from the dealer, why risk a bad setup. Get the 4 cylinder EI distributor and bolt it in. For future reference, you can swap the EI matchbox modules from the 6 cylinder and the 4 cylinder as long as the module says E12-80. The E12-93 has a function for the EFI and computer and will cause problems on an L-series 4 cylinder. Quote Link to comment
datzenmike Posted July 7, 2010 Report Share Posted July 7, 2010 As zerow said. They can be used if parts are swapped inside. I think there was someone on here who converted an L dizzy to work on a B-210 motor, or the other way round. Quote Link to comment
LenRobertson Posted July 7, 2010 Report Share Posted July 7, 2010 http://web.archive.org/web/20031006095409/home.att.net/~jason510/Dizzy_FAQ.htm Scroll down to "Donor Sources" on Jason's wonderful page, where he goes into detail on mixing and matching bits and pieces. Len Quote Link to comment
