R160 & R180 R&P
CorAce
I was reading on how to swap gear sets in R160 diffs, but what I want to know is if the LSD portion of a R180 can be used in an R160 case? for example, I have an R160 4.11 open and a R180 3.54 VLSD can I make a R160 4.11 VLSD? I know the ring gear is 20mm larger outer die., but what is the inner die.? are they the same?
  • Replies 4
  • 1 month later...
