laotsu Posted June 16, 2010 Report Share Posted June 16, 2010 I just got a '71 521 and it popped the radiator on the drive home. had a lloksee and its all soldered at the top seams so I tried JB welding it but it just keeps popping. Can I use any L16 radiator in there or would a early 80's VW radiator be a better idea? HELP? Quote Link to comment
mklotz70 Posted June 16, 2010 Report Share Posted June 16, 2010 A similar year 510 rad is the same....it will drop right in. The 620 rad is same size, but the bottom hose connection is different. Quote Link to comment
dat521kid Posted June 17, 2010 Report Share Posted June 17, 2010 my email told me you sent me a msg but when i got on here there was none. either way, i got mine done in tijuana for about 120 i think Quote Link to comment
laotsu Posted June 17, 2010 Author Report Share Posted June 17, 2010 Klotz thank you so much for keeping olddatsuns.com up man it has given me a load of help fixing up my truck Datkid can you give me more specific info on the shop? Quote Link to comment
mklotz70 Posted June 17, 2010 Report Share Posted June 17, 2010 You're more than welcome. I really need to get on there and fix all those nwde links!! Quote Link to comment
banzai510(hainz) Posted June 17, 2010 Report Share Posted June 17, 2010 see if a radiator shop can solder it up. They can tell you if rad is still good or not. as Mike said 521 rads are the same as a 510. so find a sapre also Quote Link to comment
