djaztek12 Posted June 5, 2010 Report Share Posted June 5, 2010 hey guys quick question on the 69 510 goon were is the emergency light switch at. anybody got's pictures of the way it looks :unsure: Quote Link to comment
djlotus Posted June 5, 2010 Report Share Posted June 5, 2010 In my 69 4dr theres a little pull switch just off to the side of the steering column on the bottom of the dash. Quote Link to comment
djaztek12 Posted June 5, 2010 Author Report Share Posted June 5, 2010 ok i have that but every time i pull it. it cuts my turn signal off dose it run in a separet flasher. :( Quote Link to comment
djlotus Posted June 5, 2010 Report Share Posted June 5, 2010 Well I don't know any vehicle where you can have the turn signals and hazards running at the same time. Unless I'm misunderstanding your statement/question. Quote Link to comment
datzenmike Posted June 5, 2010 Report Share Posted June 5, 2010 There are two flasher units. When the emergency 4 way flasher switch is in the OFF position there are contacts inside that close and allow the turn signals to work. When the 4 way is ON the turn signals are disconnected. The flasher unit for the 4 way may be missing. If it's there, swap it with the turn signal one. If the 4 way starts working and the signals stop then the 4 way flasher unit was bad. Quote Link to comment
djaztek12 Posted June 5, 2010 Author Report Share Posted June 5, 2010 There are two flasher units. When the emergency 4 way flasher switch is in the OFF position there are contacts inside that close and allow the turn signals to work. When the 4 way is ON the turn signals are disconnected. The flasher unit for the 4 way may be missing. If it's there, swap it with the turn signal one. If the 4 way starts working and the signals stop then the 4 way flasher unit was bad. yeah thats what happen u got it right on the money,but were is that 2nd flasher located i only see the one for the turn signals.lol :blink: Quote Link to comment
datzenmike Posted June 5, 2010 Report Share Posted June 5, 2010 I don't know about the 510 but the 620 and 720 and my 710 have the two flasher units within inches of each other. So look for a second unit or the plug for it nearby. Quote Link to comment
Pumpkn210 Posted June 5, 2010 Report Share Posted June 5, 2010 the 210s got them side by side under the dash by the column. Quote Link to comment
djaztek12 Posted June 5, 2010 Author Report Share Posted June 5, 2010 on my is near the e brake under the steering colum :mellow: Quote Link to comment
djaztek12 Posted June 6, 2010 Author Report Share Posted June 6, 2010 got any pictures. :lol: Quote Link to comment
inline4 Posted June 6, 2010 Report Share Posted June 6, 2010 speaking of flashers. is there a pinout guide to the sedan emergency blinkers? I'm going through wiring on one and the hazard switch is busted = no blinkers. Quote Link to comment
datzenmike Posted June 6, 2010 Report Share Posted June 6, 2010 Pin 4 and 5 should be connected in the OFF position. Green and Green connected in OFF This connects power from the fuse box to the turn signal flasher which connects to the turn signal switch which selects L or R and grounds through the lamps to light them. Quote Link to comment
inline4 Posted June 6, 2010 Report Share Posted June 6, 2010 Pin 4 and 5 should be connected in the OFF position. Green and Green connected in OFF This connects power from the fuse box to the turn signal flasher which connects to the turn signal switch which selects L or R and grounds through the lamps to light them. am I wrong in saying that the blinkers will not work if the hazard switch is not present? Quote Link to comment
