hazard switch
  • Replies 12
There are two flasher units.
When the emergency 4 way flasher switch is in the OFF position there are contacts inside that close and allow the turn signals to work. When the 4 way is ON the turn signals are disconnected.
The flasher unit for the 4 way may be missing. If it's there, swap it with the turn signal one. If the 4 way starts working and the signals stop then the 4 way flasher unit was bad.
yeah thats what happen u got it right on the money,but were is that 2nd flasher located i only see the one for the turn signals.lol :blink:
Pin 4 and 5 should be connected in the OFF position. Green and Green connected in OFF
This connects power from the fuse box to the turn signal flasher which connects to the turn signal switch which selects L or R and grounds through the lamps to light them.
am I wrong in saying that the blinkers will not work if the hazard switch is not present?
