Jassifrass Posted May 12, 2010 Report Share Posted May 12, 2010 is all crusty and corroded, i think i should probably replace it? Quote Link to comment
zerow Posted May 12, 2010 Report Share Posted May 12, 2010 is all crusty and corroded, i think i should probably replace it? relay for, i think, the rear window defroster Quote Link to comment
zerow Posted May 12, 2010 Report Share Posted May 12, 2010 And simply remove and clean it with something non-corrosive Quote Link to comment
Jassifrass Posted May 12, 2010 Author Report Share Posted May 12, 2010 that would explain why its never worked! :lol: Quote Link to comment
zerow Posted May 12, 2010 Report Share Posted May 12, 2010 Are you needing one? I would need to check the parts stash to see if it is part of the items taken off the parts car before I traded it. Quote Link to comment
Jassifrass Posted May 12, 2010 Author Report Share Posted May 12, 2010 maybe im not sure. I'll see if i can get it out later and clean it. i dont know how to test it though...like get the windows to fog up...boil some water and jump in the back with it? Quote Link to comment
hang_510 Posted May 12, 2010 Report Share Posted May 12, 2010 i dont know how to test it though...like get the windows to fog up... try getting hot and heavy in the back seat??? ;) ;) when the cops knock on the window, you can hit the switch! :blink: Quote Link to comment
zerow Posted May 12, 2010 Report Share Posted May 12, 2010 maybe im not sure. I'll see if i can get it out later and clean it. i dont know how to test it though...like get the windows to fog up...boil some water and jump in the back with it? You would check for voltage at the rear window, there is a connector where it meets the glass of the back hatch. and when the relay works, there is an audible click, especially since the plastic trim is removed from the inside below the fuse box, you will hear it right away. (Turn off stereo first...) Quote Link to comment
datzenmike Posted May 12, 2010 Report Share Posted May 12, 2010 There is a relay but also a timer, that's what all the solder is. There must be a small circuit board there too. Quote Link to comment
