what the hell is this?
  • Replies 8
Are you needing one? I would need to check the parts stash to see if it is part of the items taken off the parts car before I traded it.
maybe im not sure. I'll see if i can get it out later and clean it. i dont know how to test it though...like get the windows to fog up...boil some water and jump in the back with it?
You would check for voltage at the rear window, there is a connector where it meets the glass of the back hatch. and when the relay works, there is an audible click, especially since the plastic trim is removed from the inside below the fuse box, you will hear it right away. (Turn off stereo first...)
