Weber Caburetor Kits?
Benkrwn
  • Replies 5
webercarbsdirect also.
I like the 5A version as its a manual pull cable type choke. you might need to buyt the cable.
If yo have a eleltric choke you might want to get the E(Electric choke) version or the IC version with the idle cut off(incase you get a later open chamber head had have dieseling proplem when you shut key off. I just make a double lug wire at the choke then continui on to the seliniod.
warning most those carb adapters in the kit are the cheap thin ones so dont over tighten.
ck your ignition first if still running points. a condensor or a worn out bushing that cause the dizzy shaft to wiggle will give backfireing soemtimes making it look like a carb going bad.
