74datsun620 Posted April 17, 2010 Report Share Posted April 17, 2010 Bleed the brakes and ajust them, Then with truck jacked up make sure they lock up. P.S. 620 drum brakes suck even when working perfect compared to other cars and trucks. There are disc brake conversions on Ratsun but most require 15" wheel. Quote Link to comment
Vegas Posted April 17, 2010 Author Report Share Posted April 17, 2010 Bleed the brakes and ajust them, Then with truck jacked up make sure they lock up. P.S. 620 drum brakes suck even when working perfect compared to other cars and trucks. There are disc brake conversions on Ratsun but most require 15" wheel. ok. i think ill get it done tonight or in the morning. i literaly refuse to drive a whole day with the brakes this way. if i do the conversion, ill do 5 lug at the same time im sure. thats waaay down the road. the brakes are new he said. just need bled Quote Link to comment
pharouh Posted April 17, 2010 Report Share Posted April 17, 2010 If bleeding doesn't help much,you'll need to adjust them. It's on the bottom of the backing plate. A lot of times they'll get stuck from lack of use or corrosion.The only fix is to take them apart. Been there done that. Quote Link to comment
Vegas Posted April 17, 2010 Author Report Share Posted April 17, 2010 hmm sweet deal. they must have been apart recently cuz he put new shoes all around. but thanks man Quote Link to comment
