butcherboyjc Posted March 31, 2010 Report Share Posted March 31, 2010 I'm re-building the front end and I purchased 14mm balljoints instead of the 11mm that I needed. So now I can't put my strut assembly back in. What is the the part called that is bolted on the balljoint and the outer tie-rod end (picture below). Would it be easier to buy another set of ball joints or maybe someone on here has an extra set (of the pic below) that is for a 14mm balljoint, that they don't need. I really don't want to spend another 80 bucks on a set of ball joints just yet. Or is there a interchangeable part that I can try to get from a local jy like from the early Z's? Quote Link to comment
philcas1987 Posted March 31, 2010 Report Share Posted March 31, 2010 Knucle? Just drill that shit out! Quote Link to comment
butcherboyjc Posted March 31, 2010 Author Report Share Posted March 31, 2010 I dont know if that would work? I believe it is a tapered hole. Quote Link to comment
bonvo Posted March 31, 2010 Report Share Posted March 31, 2010 I dont know if that would work? I believe it is a tapered hole. it is take it to a machine shop and tell them you need it made a certan size Quote Link to comment
MicroMachinery Posted March 31, 2010 Report Share Posted March 31, 2010 Yeah, that's your steering knuckle, it is tapered. I wouldn't F with it.. that'd be a shame to have to go looking for another one of those.. Can't you just take the ball joints back? Do it right man. Quote Link to comment
bonvo Posted March 31, 2010 Report Share Posted March 31, 2010 Do it right man. hence why i sugested a machine shop bigger ball joints would be better anyway and if you go to a good machine shop it will be like they came factory that way Quote Link to comment
sssr20det510 Posted March 31, 2010 Report Share Posted March 31, 2010 get some knuckels from a 70-73 and bolt them up Quote Link to comment
butcherboyjc Posted March 31, 2010 Author Report Share Posted March 31, 2010 Thanks, I will post in the wanted section that I need 70-73 knuckles. I purchased the balljoints on line and I dont want to deal with returning them through mail. Quote Link to comment
butcherboyjc Posted April 1, 2010 Author Report Share Posted April 1, 2010 Problem solved. I picked up a set of knuckles from James Johnson. Thanks everyone. Quote Link to comment
