pope_face Posted November 24, 2007 Report Share Posted November 24, 2007 Alright, I found out I can't use a KA auto with my engine if I remove the ECU, so I need to figure something else out. I know that some people had bolted an L-Series transmission to a KA block using the Z (Z22E, Z22S, etc) bell housing... I was going to go that route, but like an idiot I didn't connect using a Z bellhousing with using the entire transmission... Now, the KA is electronically controlled by the engine ECU... the L-Series auto transmission is hydraulically controlled. Does anyone know how the Z (NAPS-Z?) automatic transmission is controlled? Quote Link to comment
datsunaholic Posted November 24, 2007 Report Share Posted November 24, 2007 That NAPS-Z transmissions are the same transmission as a L-series (with different bellhousing), through at least '86. Later ones added overdrive and/or lockup torque converters, but still work. Quote Link to comment
pope_face Posted November 24, 2007 Author Report Share Posted November 24, 2007 Awesome, thanks... I suppose I'll be looking for a later one then. Quote Link to comment
datzenmike Posted November 25, 2007 Report Share Posted November 25, 2007 That NAPS-Z transmissions are the same transmission as a L-series (with different bellhousing), through at least '86. Later ones added overdrive and/or lockup torque converters, but still work. The L3N71B came out in '82 so the '83s might have had the locking torque converters on the 720. The '84s did for sure. Quote Link to comment
