Loco2crasy Posted March 3, 2010 Report Share Posted March 3, 2010 What do I do know hahahahaha Any suggestions? Quote Link to comment
HRH Posted March 3, 2010 Report Share Posted March 3, 2010 Uuuuuhhhhh...clean it up and put it back together? Quote Link to comment
banzai510(hainz) Posted March 3, 2010 Report Share Posted March 3, 2010 get a FELPRO gasket set and bolt it back together watch olddatsuns.com tech section L series timming chain install. http://www.guba.com/general/search?query=hainz&set=5&x=0&y=0 PS get a Jap cam timming sprocket. You have the shitty one where you cant see the Timming mark. Trust me Quote Link to comment
Loco2crasy Posted March 4, 2010 Author Report Share Posted March 4, 2010 Thanks Banzai, I will do. Any other suggestion on decent parts I could put in. Don't want to go to cheep and break down on me cause of it. Quote Link to comment
banzai510(hainz) Posted March 4, 2010 Report Share Posted March 4, 2010 This is my opinion here. you either do a full rebuild $$$$$$$$ or just keep it running. Ig you want to go on the cheaper side. I would get the head gasket set/front cover set from Felpro. and get the spocket that has the 4 inspection holes so you can see the v notch thru it. and maybe get a new chain tensioner and slock side guide. Maybe cheaper if you can get a timming chain kit. but get a good set. Do not get the Cloyes or Melling brand as the y have those lame 3 inpection hole sprokets. But I dont know the history of this motor only you do . Really depends if this is a oil burner or not. Quote Link to comment
racerx Posted March 4, 2010 Report Share Posted March 4, 2010 It really depends on funds and skills. If you have both then rebuild but do a compression check first. Quote Link to comment
