dbuzz77 Posted March 4, 2010 Author Report Share Posted March 4, 2010 1 more question, my blaster 2 instructions say to run a .8 ohm resistor with a stock dist. is this true? i bypassed the stock resistor because of an article i read. the vid was good, very informative. Quote Link to comment
banzai510(hainz) Posted March 5, 2010 Report Share Posted March 5, 2010 If you have a Matchbox dizzy and a Blaster 2 coil YES you can bypass the the resisitor. Those coils can handle the full voltage. the ballast resistor is used of you still have points and useing the stock COIL or use a Points conversion where you want the current lower otherwise it will burn up the points or Pertronix,Unilite ect...... Quote Link to comment
dbuzz77 Posted March 6, 2010 Author Report Share Posted March 6, 2010 great, thanks again. Quote Link to comment
