WTT - 1972 Datsun 510 Wagon KA24DE
Things I'm looking for:
WRX/Evo
Frontier/Tacoma/Import truck (looking for double cab)
Q45/LS400/VIP'able car
IS300
Something 2000ish or newer that's fun and an import, let me know what you have!
I'm open to spending a little or being paid a little depending on the car, it doesn't have to be a dead even trade.
I'm not set on getting rid of it, but I'm trying to explore my options. It's hard for me to focus on pushing toward a career right now when I've got a car that I want to work on and sink money into.
Please call, text or email with any questions or for offers.
Sean
916.505.81O8
essdeezy87@yahoo.com
Full build thread can be found here:
http://community.ratsun.net/topic/8891-510...charged-ka24de/
Motorset
-1994 KA24DE
-JUST swapped a low mileage dual cam in. Inspected the pistons and bearings, and everything checked out. Has a brand new Cometic Headgasket, new oil pan gasket, new timing chain lower and upper set, new tensioners and guides, new front and rear main seals, etc, etc. Everything on the motor for the most part has been painted/polished/powdercoated. Using Nology Hotwires, and the distributor has a new cap and rotor. Uses a Fidanza lightweight flywheel, and a Centerforce centrifugal pressure plate and aggressive street clutch disk.
-Wiring harness and ECU are from a 1995, to make full use of the F3 plug. The harness is wired in using the Female side of the F3 plug, so the full engine harness can be removed without cutting any wires. The engine harness and F3 plug were also de-pinned of all unnecessary wiring the proper way, and the interior side of the harness was shortened about a foot, so it mounts neatly to the kick panel and I planned on making a cover for the ECU and the piggyback I would have used for the supercharger.
-Included is everything I've acquired for the Supercharger swap I'd been building. This includes: two Eaton M62 blowers, one in bad condition, can be used for mockup, rebuild or sale, and one that was opened, cleaned, ported for wastegate, sound reduction holes welded, and polished/painted. Brand new oil is ready to be put in. Also including a .5" aluminum adapter plate for the KA manifold to Eaton blower with tapped ports for IACV, vacuum and boost gauge, an upper intake manifold with no butterfly valves that has been polished and cleaned, and already has SR20DET 370cc injectors installed in a freshly cleaned KA24DE fuel rail on it. Intake elbow and piping, couplers and clamps are all ready to be bolted on once everything is on the motor. I also have a Alternator bracket/boost belt tensioner that can be used or modified to make better. A GReddy Emanage Blue, misc oil filter relocation parts and other misc parts are also included in the "kit."
-Transmission is a low mileage S13 5 speed that was owned by an older couple, then sold to a younger gal. Shifts smoothly into all gears, and was cleaned inside the bellhousing and out, and has been painted True Blue with several layers of clear coat to make it easier to clean up for a show. Has a brand new Throwout Bearing installed.
-Datsun 521 Clutch Master Cylinder helps to redirect the clutch line to an easier location, connects to a SS braided line and new KA slave cylinder.
-Uses a stock 510 sedan driveshaft (painted chrome) that goes to a stock wagon axle with fresh gear oil (painted gloss black).
Interior
-Starting at the front: Stock gauge cluster surround, radio bezel (has been cut at one point to fit a stereo, am using a DATSUN plate as a radio delete), and glove box. Gauges are a stock 510 Speedometer (possibly broken, might be able to fix it), stock 510 Tachometer and the temp/gas gauge has been replaced with an AEM wideband gauge to monitor the air/fuel mixture in the exhaust. Glove box has a metal BRE badge. I also have installed an electric water temperature gauge, mechanical oil pressure gauge and a nice programmable fuel gauge under the ash tray in a 3-gauge cluster. Dash pad is a stock 510 pad that has had cracks repaired, and was upholstered over with a foam base and black vinyl material. Gives the dash pad a little "squish" and looks modern.
-Steering wheel is a Momo 510 hub, connecting to a NRG slim quick release (lets you remove the steering wheel), and is bolted to a Maziora 350mm JDM steering wheel (changes color in light from Green, to Gold, to Purple) with chrome spokes. I can also include a 350mm NRG wheel which has black spokes and black leather wheel with a Yellow center marker if you prefer it.
-The interior is carpeted using the typical Loop Pile carpet in front passenger area, and I used black "indoor/outdoor" carpet under the rear seats and into the cargo area for a more durable, but still matching, carpet kit.
-Datsport transmission tunnel cover shoots up to a stock KA shifter and two 3" aluminum shifter extensions topped with a Hurst "pistol grip" shift knob. Shifter extensions can be removed if you prefer.
-Front seats are from an early 90's BMW 3 series and are black leather with very minor cracks, no tears. They are very comfortable, and hold you in place very well without being too aggressive. Rear seats are stock 510 wagon, and are not currently installed, but I will include seats and all brakets to reinstall them if you want.
-Currently has no headliner, but roof has been sprayed with textured "bed liner" paint which has reduced a fair amount of vibration and noise. Also sports a "newer 510" dome light and lens that functions perfectly.
-Has all door panels, kick panels and interior handles.
-Ignition has been rebuilt using NEW key cylinder and ignition switch, and has a functioning steering wheel lock.
-Optima redtop battery is mounted behind passenger side rear seat using a FBI Billet Aluminum Optima mount, which holds it from the bottom for a clean look and to eliminate the chances of shorting to a post across the top. Thick gauge battery cables are run using new post clamps, and the rear seat folds up and down without interfering with the battery or wiring.
Suspension
-Front: 280zx struts have been shortened and use rear MR2 Tokico Illumina shocks. Shaft collars hold up Ground Control adjustable sleeves and Eibach 300# springs under Ground Control camber plates.
-NEW 280zx Brake Master Cylinder runs to NEW stainless braided lines.
-Brake pads have tons of meat on them. Wheel bearings were replaced and greased recently, and make no noise upon spinning.
-I replaced the stock 280zx wheel studs with extended Nismo studs front AND rear for more aggressive aftermarket wheel options, and the option to run spacers if you need to.
-Front struts were painted High Gloss Black, covered with a rainbow metalic flake mixed into the first 3 layers of clear, and followed with several more layers of clear to keep them clean easier.
-Rear: 510 wagon leaf springs were professionally de-arched and stiffened and feel GREAT compared to the front spring rate. Leaf springs have NEW FACTORY bushings front and rear, and longer U-Bolts to clamp down on 2.5" steel lowering blocks that feature a pinion adjusting "tilt" to keep the driveshaft angle correct at the new ride height.
-Shocks were replaced with KYB OEM replacements when I bought the car a few years ago, and feel good, though they're the only weak point in the rear suspension.
-Drums were taken in and surfaced, and all shoes have been inspected to make sure the rear brakes were good, as this was a car I've been driving every day. Rear wheel cylinders have been replaced with brand new ones, and the brakes feel great front and rear. Car stops when you tell it to.
-Rear is using a sway bar with brand new hardware, though I'm not sure of the brand.
-Suspension pieces in front have been powdercoated (adjustable T/C rods, control arms, crossmember)
Body
-To be honest, most every panel needs some work. The car looks GREAT in pictures and from 10' away, but if you're looking for show quality body work and paint, this car needs a bit before it's at that point.
-Valance was a NOS piece for the project it was originally mounted on and never driven. Mounted on it is a BRE Spook chin spoiler that should be replaced.
-Grill surround trim is all there and in good shape (eyebrows, hood trim and lower trim).
-Front fenders are full fiberglass BRE style bubble flared fenders and have some minor damage, but look great from 10' away.
-Hood is in GREAT shape
-Doors all open and close, though the driver's door latch needs to be adjusted because you have to close it hard for it to hold the latch.
-Front windshield is a NOS replacement and has ZERO pitting.
-All glass is in great shape, though the hatch glass does have a small gouge in it from what looks like a rock someone hit it with a long time ago. It's not cracked, just gouged a little.
-I imported metal window visors from Malaysia, which really make the car look cool, in my opinion.
-All weatherstripping is new EXCEPT for the cargo windows and hatch window and rear 1/4 windows. Front windshield, interior/exterior window squeegies, front and rear door, front and rear window channel felt, wiper boot seals were all replaced and the car stays DRY inside!!
-Rear fenders have been pulled to accept my wheels at this ride height. I can have them reworked to be a bit cleaner if you like, or I can include the rear box flares if you want to continue the project where I've left off.
  • Replies 10
Things to Note
-The wheels that are currently on the car (Hayashi Racing - Talon) will NOT be coming with the car. The wheels are my brothers and he doesn't plan on getting rid of them. We can work out a possible set of Longchamps or you can provide your own set.
-The Bluebird grill... I would PREFER not to get rid of. If it's worth it to you, we can work something out. You would be getting a fully polished 70-73 grill.
--Details on the grill: I got it with zero cracks or issues, tore it all apart and stripped the paint. I repainted the metal center Gloss Black, and polished the top trim lines. I also painted the plastic bezels Gloss Black with Chrome trim lines.
--Another note, we also have a 68 grill that could be installed instead... But again, I would prefer to get rid of the car with the 70-73 polished grill.
-The roof rack as well is not included, but if it has to go, I'll let you have it, we can work it out.
-Car comes with lots of extras, as well, like an underdash A/C unit with wiring and fan, bolt on dump pipe to replace muffler, extra wheel bearings for the front, and other little goodies.
There are many things about the car that I haven't touched on, I'm sure, but if you skim through the past 25 pages of this thread, you'll see the work put into it. I easily have over 10k into the car, not including the supercharger kit or the new motor, but obviously don't expect to get 10k for it! Again, I'm just looking for something new, I guess... All the work that I want to do on the car right now requires taking it off the road, and I can't do that right now.
Pictures from the Sacramento Datsun Swap Meet Sunday
We'll see. As I've said, I'd be happy to keep it if nobody bites on a trade, but I'd be just as happy to see someone else enjoy it. This has been my first project and I want to work on others at some point! Just have to see what comes of it.
  • 2 weeks later...
Hey, I am new here and am still learning about Datsuns, but the reason I joined is to get one.
I have a Black 2005 WRX w/ 73k miles, exhaust, Cusco sway bars, and Cobb springs. If we decided on a trade, I would most likely want the car + $5k. The reason I want to sell/trade my WRX is to avoid smog and to pursue classic Japanese cars.
Feel free to PM me and we can chat about it.
So I think I'm going to hold off on trading the car and instead list the car at $7000 with a set of Longchamps, $6500 with your own wheels. (Note: Car is equipped with 280zx front struts, and will not fit 13" wheels and some 14" wheels)
I am negotiable, and am still willing to trade, but am looking for a Crew Cab truck (Frontier or Tacoma).
Sean
916.505.81O8
Sean
916.505.81O8
hey it was good talking to you yesterday. If I had the cash right now I would buy it, but I have to sell the WRX first. But if you decide that you would rather have a WRX, let me know so we can trade. haha
-Rob
