sick620 Posted February 22, 2010 Report Share Posted February 22, 2010 How hard would it be to throw in a q45 rear axel under a 620? I want lsd. Is there a better car to get a lsd rear diff from? Quote Link to comment
datzenmike Posted February 22, 2010 Report Share Posted February 22, 2010 Vg Hardbody 4X4 with standard tranny have 4.375 H-233 LSD. You would have to cut the leaf spring perches off and re-mount on the underside of the axle tubes. They are a couple of inches wider than the 620 (maybe too much) are available with rear disc, are larger than a Ford 9" and the 620 rims fit the bolt pattern. Quote Link to comment
yellowdatsun Posted February 22, 2010 Report Share Posted February 22, 2010 Just going on a wild assumption here, but isn't the Q45 independent? Quote Link to comment
sick620 Posted February 23, 2010 Author Report Share Posted February 23, 2010 Wait mike is it longer or wider? because I dont see how wider might pose a problem unless of course the U bolts no longer wrap around it but I could just get bigger ones and redrill the holes in the mounting brackets on the shocks right? Quote Link to comment
datzenmike Posted February 24, 2010 Report Share Posted February 24, 2010 Distance side to side between rims. It's around 150cm/ 59". Probably too big, I mean wide. Quote Link to comment
72240z Posted February 24, 2010 Report Share Posted February 24, 2010 Well considering the cutting and welding you'd have to do to get a irs in isn't that semantics? Wouldnt the lsd out of a d21/d22/pathy be way easier? Quote Link to comment
