Q45 rear axel in 620?
sick620
  • Replies 5
Vg Hardbody 4X4 with standard tranny have 4.375 H-233 LSD. You would have to cut the leaf spring perches off and re-mount on the underside of the axle tubes. They are a couple of inches wider than the 620 (maybe too much) are available with rear disc, are larger than a Ford 9" and the 620 rims fit the bolt pattern.
