SRSANDS Posted February 19, 2010 Report Share Posted February 19, 2010 Im am bored today and I have to run some grounds on the VG. I got a fatty from the block to the frame rail, and a small braided one from the starter to the other frame rail. Where else would one suggest I add more? Is a intake manifold to firewall ground necessary? I just want to make sure I have enough through out the bay as I have heard strange horror stories of electrical current doing wierd shit and also frying the ecu......... Quote Link to comment
Jesse C. Posted February 19, 2010 Report Share Posted February 19, 2010 Sounds like you have it well grounded already. The wiring itself has its own grounds and all the assorted items that connect the engine to the car in someway are also acting as grounds. Quote Link to comment
Unclejesse88 Posted February 19, 2010 Report Share Posted February 19, 2010 You can never have too many grounds. You need a ground from the battery to body, and from body/battery to engine. Just think of how much current is going TO the engine, and the fact that it will have to return to the battery. So, that means you need a engine to battery ground that is at least as large as your starter cable. You also could use another ground for your engine controls, ecu, ignition etc. If you don't have enough grounds, then yes you can get failures like electrons trying to use your throttle cable as a ground. Remember also that any ground attached to the body needs to be cleaned of paint prior to bolting it to the body. Quote Link to comment
yellowdatsun Posted February 19, 2010 Report Share Posted February 19, 2010 You just need the one wire from the body to the engine, that's it. When people start throwing a zillion ground wires on their cars it means they have another problem that needs to be addressed. The entire engine is one giant chunk of metal, and it's all connected with bolts, so one ground is fine. On my VG30 I have a single fatty braided ground cable going from the chassis to the pass side engine mount, that's it, works perfectly. Quote Link to comment
