67411sss Posted February 3, 2010 Report Share Posted February 3, 2010 So i have this cam and am confused as to the stamping on it, i've already asked Skib but thought i would share the mystery... Quote Link to comment
MAG58 Posted February 5, 2010 Report Share Posted February 5, 2010 This Came off of an E30 BMW? M10 or M20? Quote Link to comment
fisch Posted February 5, 2010 Report Share Posted February 5, 2010 Does it have MGB scribed into it? But is that a Japanese kanji stamping? Could it be that it came out of a E1 mid 60's datsun (320, 410, etc.) engine and was either used in a MGB B-series (not sure if this was possible) or was used in a e-series Datsun head on a MGB b-series block? Seriously I have no idea. But when I hear MGB and E-series at the same time, that is where my mind goes since the C1, E1 and J's were copies of the MGB BMC B-series engines. Quote Link to comment
MAG58 Posted February 5, 2010 Report Share Posted February 5, 2010 Scratch that, it's an L series cam (IIRC most of those motors you've mentioned fisch should have some fashion of cam drive on the back of it). I don't think it's a re-grind from a cam company in the states, that's not a mfg or grind I'm familiar with. Can you tell what cam it was based off of? Or was it ground from a blank? Quote Link to comment
67411sss Posted February 5, 2010 Author Report Share Posted February 5, 2010 It's an L6 cam, made by nissan (has japan cast into it)i just can't make out the stamp, could be a K( but nissan don't have a K cam for the L6)I don't know if it started out as a blank(do blanks have a stamp?)i guess i could take it down to the machine shop and get them to measure the lobes, just thought i would ask here. Quote Link to comment
Skib Posted February 5, 2010 Report Share Posted February 5, 2010 It's an L6 cam, made by nissan (has japan cast into it)i just can't make out the stamp, could be a K( but nissan don't have a K cam for the L6)I don't know if it started out as a blank(do blanks have a stamp?)i guess i could take it down to the machine shop and get them to measure the lobes, just thought i would ask here. ya its deff not a factory stamping :huh: if you got the lobes measured it might help narrow it down Quote Link to comment
SHADY280 Posted February 5, 2010 Report Share Posted February 5, 2010 e30 is the head type? the stamp is prolly a japan company re-grind. the e heads were japan only if i remember what i read on hybridz somewhere. i could be wrong. i should check my e head i have, but its put way far away. Quote Link to comment
Skib Posted February 5, 2010 Report Share Posted February 5, 2010 e30 is the head type? the stamp is prolly a japan company re-grind. the e heads were japan only if i remember what i read on hybridz somewhere. i could be wrong. i should check my e head i have, but its put way far away. most if not all the L6 cams have "E30" cast into the side, My J grind P90 cam and A grind cam have the same casting. as far as E heads go we got the E88 and the E31. Im thinking its an after market from a JP company? a regrind of a factory cam would still have the factory stamp on it Id think. either way its not stock. Id go see what the cam specs are Rory. Quote Link to comment
67411sss Posted February 5, 2010 Author Report Share Posted February 5, 2010 Its a factory nissan cam for a 6 cylinder L series, has JAPAN and E30 cast into it. It's NOS, it might be for the L20A 6 cylinder... Quote Link to comment
Skib Posted February 5, 2010 Report Share Posted February 5, 2010 Its a factory nissan cam for a 6 cylinder L series, has JAPAN and E30 cast into it. It's NOS, it might be for the L20A 6 cylinder... thats true, Ill see if I can find some L20A cam specs, Iv got all the american L6 specs but that ones JDM I asked over at HybridZ too, there some guys who have spent a lot of time with JP spec Z stuff and would know those random bits of obscure info lol. Quote Link to comment
67411sss Posted February 6, 2010 Author Report Share Posted February 6, 2010 Heres a pic of the profile, look stock to you? Quote Link to comment
Skib Posted February 6, 2010 Report Share Posted February 6, 2010 I talked about it with Paul tonight and you should deff have the lobes measured and see what the lift/duration is and snap as many pics as you can :D Quote Link to comment
MAG58 Posted February 6, 2010 Report Share Posted February 6, 2010 It's pretty hard to look at a cam and be like... Oh that's obviously not stock, unless it's a pretty meaty cam. I can tell you it looks like an asymmetric grind though which isn't stock. Quote Link to comment
Skib Posted February 6, 2010 Report Share Posted February 6, 2010 so far Im thinking its a Nissan blank thats been cut by someone, I dropped by BRAAP's yesterday and talked about it with him some. Quote Link to comment
