JDM510 Posted February 1, 2010 Report Share Posted February 1, 2010 ok so i have a few questions for a KA swap, i been searching found most of the info i need... witch speedo sender do i use with the KA tranny to make my stock speedo work???? my car was auto so my cable should be long enough. i just need to know what sender... first gen 300zx??? Quote Link to comment
INDY510 Posted February 1, 2010 Report Share Posted February 1, 2010 I looked at the dimequarterly tech section; under KA swap: He said he used a first gen 300zx speed sensor.......because the 280zx speed sensor was leaking and didn't work properly. He also said he used a stock 510 automatic speedo cable....___so i guess you were right.. :huh: Quote Link to comment
Spades Posted February 2, 2010 Report Share Posted February 2, 2010 the cable should be about the right length...as far as what sender to use, not sure. I kind of doubt there is a direct bolt in drive that will have your speedo completely accurate though...I have a naps-z20 with a manual transmission from a 1980 nissan 510(called a 510 but is actually a nissan stanza) in my wagon, and even though the cable bolts up just fine to the sending unit on the 80's transmission, my speedo is over 10mph off because of the lower gears my wagon has...I would assume even if you can get a drive that will pop into the 5spd, I kind of doubt it will be accurate. Quote Link to comment
JDM510 Posted February 2, 2010 Author Report Share Posted February 2, 2010 i picked one up from a first gen 300zx today we will see how it works out... i dont mind if its off a lil, but we will seo how much it is... Quote Link to comment
Docsis510 Posted February 2, 2010 Report Share Posted February 2, 2010 i have the z31 on my 510 but it does leak oil. the oil comes out through the cable. Quote Link to comment
JDM510 Posted February 3, 2010 Author Report Share Posted February 3, 2010 i was looking into my speedo cable and i see theirs a seal in their.. maybe your seal is bad mine looks to be ok so we will see once i get it running... another question... my datsun is a 71 auto car and their is no fuel return line??? do i run my own?? obviously... im wondering am i going to have to weld a nipple on my tank??? where is the best place to dump this return??? in the top of the tank or bottom??? Quote Link to comment
NorCalDime Posted February 3, 2010 Report Share Posted February 3, 2010 i thought you had done numerous ka swaps? Quote Link to comment
NorCalDime Posted February 3, 2010 Report Share Posted February 3, 2010 i was looking into my speedo cable and i see theirs a seal in their.. maybe your seal is bad mine looks to be ok so we will see once i get it running... another question... my datsun is a 71 auto car and their is no fuel return line??? do i run my own?? obviously... im wondering am i going to have to weld a nipple on my tank??? where is the best place to dump this return??? in the top of the tank or bottom??? My car didnt have a return either. It had a line for the vent, but i didnt use that. I ran a return line following my feed line and connected it to the bottom of the tank. There are 2 little nips on the tank in the bottom corner. The bottom one is for the inlet and the top i belive was a vent? I connected my return to that and had no issues. Quote Link to comment
JDM510 Posted February 3, 2010 Author Report Share Posted February 3, 2010 ive done a few but every one is a lil diff.. last 3 dimes a i owned all had return lines.. i just crawled under their and where the feed line for the take comes out looks like their was a gromet for the return line but some one may have removed it when they took the smog off my car??? it has the vent line though, but i think that gose threw the box under the back window so i did not wana run gas threw that Quote Link to comment
NorCalDime Posted February 3, 2010 Report Share Posted February 3, 2010 ive done a few but every one is a lil diff.. last 3 dimes a i owned all had return lines.. i just crawled under their and where the feed line for the take comes out looks like their was a gromet for the return line but some one may have removed it when they took the smog off my car??? it has the vent line though, but i think that gose threw the box under the back window so i did not wana run gas threw that maybe it wasnt a vent i cant remeber. But i thought the line that went to the box under the window was on top of the tank. At any rate i used bottom nipple for feed, top for return, inline pump in trunk Quote Link to comment
JDM510 Posted February 3, 2010 Author Report Share Posted February 3, 2010 oh and this is the first KA swap im doing that i am not buying anything for a swap. i am doing EVERYTHING my self from flipping the x member to the wiring. with the exception of the drive shaft everything else will be done by me.... and im almost 50% done :D i would start a build thread but i dont want it clutterd with bullshit and stupid comments..... cuz we all know i dont take E- criticism to well :P Quote Link to comment
JDM510 Posted February 3, 2010 Author Report Share Posted February 3, 2010 maybe it wasnt a vent i cant remeber. But i thought the line that went to the box under the window was on top of the tank. At any rate i used bottom nipple for feed, top for return, inline pump in trunk i think my top nipple runs threw that box under the back window?? did you do away with that box???? are are you speaking of another nipple Quote Link to comment
NorCalDime Posted February 3, 2010 Report Share Posted February 3, 2010 i think my top nipple runs threw that box under the back window?? did you do away with that box???? are are you speaking of another nipple reread and realize my post was cloudy. There should be 2 stacked nipples in pass corner of tank. then another on top for vent. Quote Link to comment
hang_510 Posted February 8, 2010 Report Share Posted February 8, 2010 i think my top nipple runs threw that box under the back window?? did you do away with that box???? the vent lines returns there, its for vapor recovery. Quote Link to comment
