beebeecivic Posted January 31, 2010 Report Share Posted January 31, 2010 I have been searching and searching for a pic of the "notch" on the cam pulley required to set the timing. I have looked at the fsm and haynes manual but I need a actual picture of what it looks like. Any help would be nice thanks! btw I checked on hybrid with no luck :( -bee Quote Link to comment
72240z Posted January 31, 2010 Report Share Posted January 31, 2010 Google is your friend. Quote Link to comment
beebeecivic Posted February 1, 2010 Author Report Share Posted February 1, 2010 Google is your friend. sorry 72. I didnt make it clear enough. I was looking for the one for ignition timing the one with the 0 10 20 marks. Quote Link to comment
datzenmike Posted February 1, 2010 Report Share Posted February 1, 2010 It's very small. Set motor on TDC or as close as you can and feel around the pulley edges near the timing scale bolted on the timing cover. . Quote Link to comment
beebeecivic Posted February 1, 2010 Author Report Share Posted February 1, 2010 MIKE! THANK YOU!!! that is exactly what I was looking for!!! thanks mike and 72!! quick update! I have located the notch! thank you Quote Link to comment
72240z Posted February 1, 2010 Report Share Posted February 1, 2010 pic of the "notch" on the cam pulley NP glad Mike hooked you up :-). Thats what threw me off though. Crank pully or harmonic balancer would be better. Quote Link to comment
beebeecivic Posted February 1, 2010 Author Report Share Posted February 1, 2010 NP glad Mike hooked you up :-). Thats what threw me off though. Crank pully or harmonic balancer would be better. you guys answered my question way faster then hybrid :/ two days and not a single answer.. Quote Link to comment
72240z Posted February 1, 2010 Report Share Posted February 1, 2010 They are too high and mighty to take the time. I have been on there 5 years, just gets worse and worse.... Quote Link to comment
datzenmike Posted February 1, 2010 Report Share Posted February 1, 2010 NP glad Mike hooked you up :-). Thats what threw me off though. Crank pully or harmonic balancer would be better. I had the pulley picks up and then saw you posted a cam sprocket so I tore them down and put up a sprocket... only to see it wasn't right... tore it all down again and put up the crank pulley again. It was ambiguous. :D Quote Link to comment
beebeecivic Posted February 1, 2010 Author Report Share Posted February 1, 2010 I had the pulley picks up and then saw you posted a cam sprocket so I tore them down and put up a sprocket... only to see it wasn't right... tore it all down again and put up the crank pulley again. It was ambiguous. :D What a coincidence! Going to time the Lady tomorrow :) Quote Link to comment
hughdogz Posted February 6, 2010 Report Share Posted February 6, 2010 I know it's a little late, but now that you've found it, mark it white. Paint would be the best, or use a piece of chalk. In a pinch you can use kitty-litter or even some gypsum from drywall. Just scratch it in there, and wipe the rest off that didn't get pushed into the notch. Hope this helps... Quote Link to comment
beebeecivic Posted February 6, 2010 Author Report Share Posted February 6, 2010 I know it's a little late, but now that you've found it, mark it white. Paint would be the best, or use a piece of chalk. In a pinch you can use kitty-litter or even some gypsum from drywall. Just scratch it in there, and wipe the rest off that didn't get pushed into the notch. Hope this helps... Never too late! I jus added White Out on it :P All suggestions are welcome as these topics might be viewed for other people who have trouble looking for it :) Quote Link to comment
