freaky510 Posted January 16, 2010 Report Share Posted January 16, 2010 So I had this trailer and thought it was time to upgrade it a little bit. Started with modifying a truck utility box to sit just on the trailer: then to mount the winch: then i ran into a problem I have no idea on how to hook it up it has a forward and reverse and according to Warn it should have 4 post and not 2???? this is a older Warn A2000 winch the other 2 bolt just hold on the cap Iam thinking that is is a chaise ground and the top is forward and the bottom is the reverse. I really would hate to be wrong and end up frying the winch.Any input would be great!! the winch will be power by 2 big ass battery's, After I get all the bugs worked out I might try to find a better box to put it in but this should last for a while.I will spray some rust killer on the rest of the box when it stops rainning ;) Quote Link to comment
fastdadd Posted January 16, 2010 Report Share Posted January 16, 2010 here i a down load for what looks like your winch it should help http://www.warn.com/atv/winches/A2000.shtml Quote Link to comment
DanielC Posted January 16, 2010 Report Share Posted January 16, 2010 I would get an Ohmmeter, and see if either post has a connection to the case. I do not think they do. If they do not, I think you just connect the winch up to the battery, positive to one terminal post, and negative to the other, and the winch either winds up, or unwinds. Reverse the battery connections, and the winch goes the other way. You could always wait until Monday, and call Warn. Quote Link to comment
freaky510 Posted January 16, 2010 Author Report Share Posted January 16, 2010 here i a down load for what looks like your winch it should help http://www.warn.com/atv/winches/A2000.shtml sweet how did you find that I have been all over the warn site thank you danielC I would get an Ohmmeter, and see if either post has a connection to the case. I do not think they do. If they do not, I think you just connect the winch up to the battery, positive to one terminal post, and negative to the other, and the winch either winds up, or unwinds. Reverse the battery connections, and the winch goes the other way. You could always wait until Monday, and call Warn. i will check that and i have talked with warn and that was a waste of time thank you for the input Quote Link to comment
freaky510 Posted January 16, 2010 Author Report Share Posted January 16, 2010 here i a down load for what looks like your winch it should help http://www.warn.com/atv/winches/A2000.shtml well damn thats they same manual i had an it shows the set up for the 4 post not the 2 post and I called Warn and they sent me the same thing :angry: so I guess it will have to be trail and error :( Quote Link to comment
fastdadd Posted January 17, 2010 Report Share Posted January 17, 2010 what are you using for a controller....the terminals on the winch go to the controller and the onto power found this that looks just like yours http://www.warn.com/atv/winches/images/200/60908C1_web.pdf Quote Link to comment
freaky510 Posted January 17, 2010 Author Report Share Posted January 17, 2010 what are you using for a controller....the terminals on the winch go to the controller and the onto power found this that looks just like yours http://www.warn.com/atv/winches/images/200/60908C1_web.pdf cool thanks printing now :) Quote Link to comment
