4DrSportsCar Posted January 9, 2010 Report Share Posted January 9, 2010 I installed a digital AM/FM stereo from Z-Store into my 510---drops right in the dash where the original radio was--- and the wired up Sirius Radio (the digital steres has an input jack for this. Probelm is, the AM/FM stereo sound clear, but I'm hearing the engine come through when listening to Sirius. As rpm's increase so does the feedback. Should I do something specific with the hot wire to the Sirius radio? Right now I have it plugged into the cig lighter. Quote Link to comment
freaky510 Posted January 9, 2010 Report Share Posted January 9, 2010 re do your ground Quote Link to comment
datto510 Posted January 9, 2010 Report Share Posted January 9, 2010 Sounds like somthing is interfering with your F1B signal. Quote Link to comment
MikeRL411 Posted January 9, 2010 Report Share Posted January 9, 2010 Sounds [no pun intended] like you are using solid copper spark plug wire set. Resistive wires are designed to reduce ignition noise in installed audio / radio equipment among other things. The frequencies used in the Sirius satellite link should be quite sensitive to ignition noise from an uncorrected wire set. Good luck! Quote Link to comment
shancerlelby Posted January 10, 2010 Report Share Posted January 10, 2010 sirius makes an adapter that goes inline with your factory radio http://cgi.ebay.com/Refurb-FM-Direct-Adapter-No-More-SIRIUS-Static_W0QQitemZ370317987380QQcmdZViewItemQQptZSatellite_Radio?hash=item5638ac0e34 should give you crystal clear audio. well as good as satellite radio gets anyways. Quote Link to comment
