1971datsun510parts Posted January 5, 2010 Report Share Posted January 5, 2010 I have an (been told) datsun truck posi rearend , has casting numbers 38311,2110,213 and 71-3-T29 213, can any one help with application? Also have 510 parts car , no front clip, anyone need any parts? Quote Link to comment
datzenmike Posted January 5, 2010 Report Share Posted January 5, 2010 I have an (been told) datsun truck posi rearend , has casting numbers 38311,2110,213 and 71-3-T29 213, can any one help with application? Also have 510 parts car , no front clip, anyone need any parts? Perhaps a picture of it would help. The first truck posi wasn't offered until '86 on the D-21, and that was on the H-233. The only other H-190 posi was the Roadster. 38311 appears to be a differential, I'll have to look further. Quote Link to comment
ggzilla Posted January 5, 2010 Report Share Posted January 5, 2010 The meaning of most of these numbers is undocumented. 38311 is Nissan Part Number for "gear carrier". 213 is the applied model code for Datsun 510U What are the stamped numbers on the edge of the ring gear? Are you seeing these numbers on the differential itself, or on the axle housing? What do you have this differential in? A 510 wagon? Quote Link to comment
1971datsun510parts Posted January 5, 2010 Author Report Share Posted January 5, 2010 I have an (been told) datsun truck posi rearend , has casting numbers 38311,2110,213 and 71-3-T29 213, can any one help with application? Also have 510 parts car , no front clip, anyone need any parts? Quote Link to comment
1971datsun510parts Posted January 5, 2010 Author Report Share Posted January 5, 2010 OK thanks, will get a pix and gear info. Also was told today it could be a Subaru part that was used in Datsun, it came from an 510 race car that is also for sale Quote Link to comment
datzenmike Posted January 6, 2010 Report Share Posted January 6, 2010 So not an H-190 then. R-160 VLSD? Picture will tell. Quote Link to comment
ggzilla Posted January 6, 2010 Report Share Posted January 6, 2010 It came from a 510. OK. If it was a wagon it could be an H190. Need pics. Quote Link to comment
1971datsun510parts Posted January 7, 2010 Author Report Share Posted January 7, 2010 So not an H-190 then. R-160 VLSD? Picture will tell. OK, long day @ work , here is pix of part. hope this will help, didnt get to open case and check #s on ring gear. Great, how do you add a pix? Quote Link to comment
ggzilla Posted January 7, 2010 Report Share Posted January 7, 2010 To add a pic: 1. put it on http://photobucket.com or other site where you can put photos for free. 2. When you reply here, click the "insert image" button () 3. Paste the URL of the photo in Or email it to me and i'll post it for you. Quote Link to comment
1971datsun510parts Posted January 7, 2010 Author Report Share Posted January 7, 2010 To add a pic: 1. put it on http://photobucket.com or other site where you can put photos for free. 2. When you reply here, click the "insert image" button () 3. Paste the URL of the photo in Or email it to me and i'll post it for you. Quote Link to comment
1971datsun510parts Posted January 7, 2010 Author Report Share Posted January 7, 2010 To add a pic: 1. put it on http://photobucket.com or other site where you can put photos for free. 2. When you reply here, click the "insert image" button () 3. Paste the URL of the photo in Or email it to me and i'll post it for you. Thank you, try some more pix? Quote Link to comment
1971datsun510parts Posted January 7, 2010 Author Report Share Posted January 7, 2010 Thank you, try some more pix? Quote Link to comment
datzenmike Posted January 7, 2010 Report Share Posted January 7, 2010 Pop the back off. If LSD you can tell if clutch or viscus. (or not) Quote Link to comment
1971datsun510parts Posted January 13, 2010 Author Report Share Posted January 13, 2010 Pop the back off. If LSD you can tell if clutch or viscus. (or not) Hello, C1, D1 on carrier. AJ157 37:8 (462? gearing) on ring gear. posi So can any one use this. Also have 510 limit slip , still in parts car Quote Link to comment
datzenmike Posted January 13, 2010 Report Share Posted January 13, 2010 LSD ggzilla???? Quote Link to comment
72240z Posted January 13, 2010 Report Share Posted January 13, 2010 Looks like a subi r160 VLSD to me. LSD ggzilla???? It's def lsd Quote Link to comment
datzenmike Posted January 13, 2010 Report Share Posted January 13, 2010 I meant VLSD or clutch. I'm no expert on them. Quote Link to comment
ggzilla Posted January 13, 2010 Report Share Posted January 13, 2010 Not sure, but I think it is a clutch-type LSD. Any 510 rear-end freaks here? It is a Fuji Heavy Industries R160, which came in Datsun 510s as stock equipment. But the gear ratio and LSD are not stock. It's definitely not a posi (which is a Chevrolet trademark). It is LSD, but clutch-type LSD or viscous-type LSD? * Clutch-pack LSD is a performance advantage over Viscous-coupling LSDs * Viscous-coupling LSDs are good for all-wheel drive, but not as good as clutch-pack for RWD applications. 4.625 gear ratio, good for drag racing. Quote Link to comment
72240z Posted January 13, 2010 Report Share Posted January 13, 2010 The carrier is 510 ggzilla is right. I didn't notice the extra 2 bolt holes it has. Far as I know the 510 r160 is the only one to have that. I still say its vlsd though. Without more/better pics we're just guessing but at 4.625 I feel it's a safe bet its not clutch. Quote Link to comment
