blats Posted November 1, 2007 Report Share Posted November 1, 2007 I have 200SX disk brakes that will bolt to any datsun with a solid rear axle (as far as I know) besides the 1200's H145. This means all H150s, 165s, and 190s. This includes rotors, calipers, ebrake cables, and currently mounted on H165 axles (200sx/510). I will take $100 for the setup. Link to comment
datzenmike Posted November 1, 2007 Report Share Posted November 1, 2007 Yes I gave a set to Jason on the realm for his wagon. Other than width the solid axle 510 is virtually the same as the 620. The 200sx is coil spring. Link to comment
Cruez Posted November 2, 2007 Report Share Posted November 2, 2007 awful tempting... and I just put all new pads on the wagon and coated everything... Link to comment
Jason Posted November 2, 2007 Report Share Posted November 2, 2007 Yes I gave a set to Jason on the realm for his wagon. Other than width the solid axle 510 is virtually the same as the 620. The 200sx is coil spring. Hi Mike, I'm still sitting on them now as I haven't gotten that project off the ground yet. I am thinking of shortening up the struts though, section out the rusty part and get the the right length for a 15" strut insert. Be the first set of struts I need inserts for :D! Link to comment
datzenmike Posted November 2, 2007 Report Share Posted November 2, 2007 Well, better you have them, then sitting in a field just waiting for the tow truck after the estate sale. Sooner or later, they would be scrap. Like rescuing a dog from the pound, feels good.:D Link to comment
71-521 Posted November 9, 2007 Report Share Posted November 9, 2007 so you're saying these could mount up to a pickup's backend? you have my interest... Link to comment
datzenmike Posted November 9, 2007 Report Share Posted November 9, 2007 Hmmm don't know, never gave it a thought. The 200sx disc is 4 bolt. Maybe use Trooper discs. The mounting bracket on the sx can't be removed without removing the axle bearing and might not be right for the Trooper disc anyway. Link to comment
