Sudo Posted December 16, 2009 Report Share Posted December 16, 2009 I had intermitent blinkers (I thought that feature was for wipers!) and I could NOT chase down the issue. I tried all the same things you checked. When the issue switched from the left rear to the right rear, I knew I was on to something but damned if I knew what that something was. It was a ground. The actual sockets that the light bulbs are in needed to be grounded. I assume this is because I had a bad main ground somewhere. Instead of chasing it, i ran a ground to the frame from each rear blinker. Hope this helps, good luck. Quote Link to comment
Jizital Posted December 16, 2009 Author Report Share Posted December 16, 2009 Thanks i'll check that out. Hoping to get some work done on it this weekend so i can start driving it next week. Anyone know if any other years work for the rubber hood stops? One of mine is missing so the hood drops down lower than the other side. Quote Link to comment
Jizital Posted December 16, 2009 Author Report Share Posted December 16, 2009 Just ordered some of the brackets to convert the front drums to discs. Quote Link to comment
Jizital Posted December 20, 2009 Author Report Share Posted December 20, 2009 New brake master cylinder, rear brake hose, coil, plug wires. After the brake stuff was done i went to bleed the brakes. Rear passenger side bleed valve snapped right off and then as i was unhooking the brake line to take that connector off the wheel cylinder, the hard brake lines are so old and rusted they snapped. No one has the wheel cylinder with the connector so i have to wait for it to come in the mail. Quote Link to comment
Charlie69 Posted December 21, 2009 Report Share Posted December 21, 2009 If you are going to disk brakes do not waste your money on a brake master cylinder as it will need to be upgraded for the disk brakes. Quote Link to comment
Jizital Posted December 21, 2009 Author Report Share Posted December 21, 2009 Disc brakes will be on hold for a little as i'm reading it seems like i will need new wheels for them to fit under. Quote Link to comment
Charlie69 Posted December 21, 2009 Report Share Posted December 21, 2009 Check with Mike Klotz his design will allow stock wheels, unsure if he is going to make any more. Quote Link to comment
Jizital Posted December 21, 2009 Author Report Share Posted December 21, 2009 Already have a pair of the front brackets on the way from the beebani guy or whatever his name is. Its ok because im getting some 16" smoothies in a few months. Quote Link to comment
Charlie69 Posted December 21, 2009 Report Share Posted December 21, 2009 That is great 16's look good on these trucks. Quote Link to comment
Jizital Posted March 31, 2010 Author Report Share Posted March 31, 2010 Little update. Havent really had much time to work on it due to work and a 5 month old baby so i had it brought to a buddies shop. Had him put on some new kyb shocks i bought, had the fuel tank cleaned because it had some junk it in, rebuild the carb, and it turns out the truck had all newer brake parts on it but it sat right after they were put on and the front right wheel cylinder was locked up. Quote Link to comment
sycloned916 Posted March 31, 2010 Report Share Posted March 31, 2010 Looks Good! Quote Link to comment
Sudo Posted April 1, 2010 Report Share Posted April 1, 2010 does look good. What shocks are those, I saw where you said they were KYB, but how did you know they would fit? Did you take it to a suspension shop or just measure and order? Quote Link to comment
Sudo Posted April 1, 2010 Report Share Posted April 1, 2010 does look good. What shocks are those, I saw where you said they were KYB, but how did you know they would fit? Did you take it to a suspension shop or just measure and order? nvrmnd -- Rockauto.com and I'm quickly sorted out... Quote Link to comment
Jizital Posted April 1, 2010 Author Report Share Posted April 1, 2010 Haha yea i ordered them from rock auto, thats where i have been getting most of the parts other than NOS parts im getting off ebay. Just got a NOS fuse block from hong kong to replace the old crapped out one in the truck now. I also have some plastic Datsun 1300 emblems that dont fit on the truck if anyone knows what they will fit and wants them. Quote Link to comment
Jizital Posted April 4, 2010 Author Report Share Posted April 4, 2010 carb rebuilt and clean now Quote Link to comment
Jizital Posted April 4, 2010 Author Report Share Posted April 4, 2010 buddy went for a little drive to pick up a motor i took it for a little spin yesterday Quote Link to comment
pucancakes Posted April 5, 2010 Report Share Posted April 5, 2010 where did u order the smoothies from? how much did it come out to? Quote Link to comment
Jizital Posted April 5, 2010 Author Report Share Posted April 5, 2010 those smoothies came on the truck. they have them all over online though. Quote Link to comment
Jizital Posted April 14, 2010 Author Report Share Posted April 14, 2010 had everything done and ready to drive and then the ignition went bad. buddy has been waiting on parts for the ignition because the truck wouldnt start without a ghetto jump. parts finally came yesterday and he installed them and then the truck wouldnt start without a push start. now the starter is bad and i ordered one today so once that comes in hopefully i can start doing some cleanup work and drive it a little. Quote Link to comment
