Thebandito Posted December 1, 2009 Report Share Posted December 1, 2009 okay im really curious if i messed up some how or if i put something wrong i swapped a l20 into my 72 521 and the fan hits the radiator when i try to install it or is just like that? any body know? Quote Link to comment
slam_dat_sun Posted December 1, 2009 Report Share Posted December 1, 2009 Electric fan problem solved :lol: not sure if that just how it is or not . Quote Link to comment
Thebandito Posted December 1, 2009 Author Report Share Posted December 1, 2009 realy do i got go that way dam gotta go junk yard i guess lol i didnt read it when i was readin the other post sayin i only needed the mounts and the pan Quote Link to comment
datto510 Posted December 1, 2009 Report Share Posted December 1, 2009 Was it an original L series truck? Are you using a clutch type fan? That would cause it to hit. Quote Link to comment
sdsurf Posted December 1, 2009 Report Share Posted December 1, 2009 I have an L20b in mine and have used both the clutch fan and L16 fan. No clearance issues whatsoever. Lots of people have done it, never heard of that problem Quote Link to comment
tdaaj Posted December 1, 2009 Report Share Posted December 1, 2009 might have the engine mounts mounted to the block too far back, also some clutch fans stick out farther than others. Quote Link to comment
79D50 Posted December 1, 2009 Report Share Posted December 1, 2009 There is a similar thread that was posted a couple weeks back. Did you put the motor mounts on backwards? This will shift the entire assembly forward. Key clue if you did would be that the tranny was a pain to get mounted since it was too far forward. If you go electric you can save a few HP and get better cooling. Check into http://www.flex-a-lite.com/ Quote Link to comment
Thebandito Posted December 2, 2009 Author Report Share Posted December 2, 2009 i do not think i put in the wrong engine mounts but i think i might go electric fan dont wana risk it u kno? thanks Quote Link to comment
mnementh666 Posted December 2, 2009 Report Share Posted December 2, 2009 (edited) I have a L20B in my '71 521 with no clearance issues... I don't think there would be issues even with a clutched fan. The only issue that should come up is clearances for a... different... carburetor (think short airfilter). :fu: Double check where and how you mounted it. I believe 79D50 nailed it with the tranny mounting... Edited December 2, 2009 by mnementh666 I'm retarded. Forgot a word. Quote Link to comment
moparvwfreak Posted December 2, 2009 Report Share Posted December 2, 2009 do you know if the trucks been wrecked??? i know when i did my L20 swap in my 73 620, the fan sits real close.and i am using the L16 WP and fan. non clutch. Quote Link to comment
ggzilla Posted December 2, 2009 Report Share Posted December 2, 2009 You may have put the correct mounts in. Backwards. Quote Link to comment
whitechef Posted December 3, 2009 Report Share Posted December 3, 2009 I have a L20B in my '71 521 with no clearance issues... I don't think there would be issues even with a clutched fan. The only issue that should come up is clearances for a... different... carburetor (think short airfilter). :fu: Double check where and how you mounted it. I believe 79D50 nailed it with the tranny mounting... I,ve got an L20B in my 71 as well no clutch fan and it sits just right. I have to put a rag on top of my air cleaner to keep it from touching the hood. Quote Link to comment
Thebandito Posted December 4, 2009 Author Report Share Posted December 4, 2009 You may have put the correct mounts in. Backwards. o god man if thats hte problem ima be pissed lol and i forgot who i lent my cherry picker too >.< time to find a straw berry picker Quote Link to comment
