zerow Posted January 18, 2010 Report Share Posted January 18, 2010 Well that didn't last long, the Alternator crapped out, so now I'm going to attempt to return the 610 alt on a warranty exchange w/ my Z alt to get a better one for free. Need to find the write up on how to do that Dimequarterly has the best writeup, IMO. Quote Link to comment
nbesheer Posted January 18, 2010 Author Report Share Posted January 18, 2010 Haha per Zerow's wealth of information apparently I have a 50 amp b210 amp. lol Quote Link to comment
zerow Posted January 18, 2010 Report Share Posted January 18, 2010 "Zerow's wealth of information" - Thanks nbesheer...Its truly sad the collection of things I have in my 'Datsun' folder on this computer. We need a Trivial Pursuit-Datsun Edition... Quote Link to comment
bonvo Posted January 18, 2010 Report Share Posted January 18, 2010 We need a Trivial Pursuit-Datsun Edition... best swapmeet game evar!!!!! Quote Link to comment
nbesheer Posted January 18, 2010 Author Report Share Posted January 18, 2010 well I got the reman 280ZX alternator I'm going to try and return the old b210 alt later today on my way to OC. Quote Link to comment
nbesheer Posted January 18, 2010 Author Report Share Posted January 18, 2010 HAH! Got a new alt under warranty now I need to do some mounting and what not but I'll be at work till friday so I can't work on it now :( Quote Link to comment
nbesheer Posted February 12, 2010 Author Report Share Posted February 12, 2010 Well I finally got the IR alternator in so happy it works now. was actually way easier then I thought. also my headlights are a bit less yellow now too. Quote Link to comment
bonvo Posted February 12, 2010 Report Share Posted February 12, 2010 woot i need to do the ir swap on mine as well Quote Link to comment
zerow Posted February 12, 2010 Report Share Posted February 12, 2010 Well I finally got the IR alternator in so happy it works now. was actually way easier then I thought. also my headlights are a bit less yellow now too. Way to go! You'll know how well it works when you drive at night for the first time after install. Also, pull the ground for the headlights, sand the ring, re-install, and spray with WD-40. You'll see a HUGE improvement then! Quote Link to comment
nbesheer Posted February 14, 2010 Author Report Share Posted February 14, 2010 So the new alt requires more engine power to turn it so I need to up the idle a bit but am I going to turning the screw that physically turns the throttle linkage, or is there a better way to do that ? Quote Link to comment
zerow Posted February 15, 2010 Report Share Posted February 15, 2010 So the new alt requires more engine power to turn it so I need to up the idle a bit but am I going to turning the screw that physically turns the throttle linkage, or is there a better way to do that ? Nope, thats the one. Theres a plate that the screw pushes against to open the throttle a little wider to up the RPMs. Quote Link to comment
nbesheer Posted February 15, 2010 Author Report Share Posted February 15, 2010 sweet and what's a good idle rpm for a L18 with this alternator ? (1983 280zx alt) EDIT: also zerow you remember that fuel/vapor hard line I mentioned to you that ran to the passenger wheel well. Well the hose/bolt the PO used to block it off has a pin hole leak. What is the best way to block off a barbed hard line w/o damaging it ? Quote Link to comment
zerow Posted February 15, 2010 Report Share Posted February 15, 2010 sweet and what's a good idle rpm for a L18 with this alternator ? (1983 280zx alt) EDIT: also zerow you remember that fuel/vapor hard line I mentioned to you that ran to the passenger wheel well. Well the hose/bolt the PO used to block it off has a pin hole leak. What is the best way to block off a barbed hard line w/o damaging it ? You have stick, so stock was +/- 800rpm. I wouldn't go any higher than 925, if I could avoid it. I remember the hard line. That PO of your car = asshat. There are rubber plugs that push over the end of those hardlines to block them off. I would try the local auto parts store. Dorman/Motormite *should* have something in stock for the application. Or go old school and melt a rubber vacuum line at the end and create your own plug... Quote Link to comment
nbesheer Posted February 16, 2010 Author Report Share Posted February 16, 2010 Alright So I can set the RPM on... friday ? lol and I need to go junkyarding for a alt bracket that looks like my S130 one, a lower mounting bolt for the alt, as my po only mounted w/ one, and then the little brackets and bolts that mount to the bottom of the engine and the front of the trans as I don't have those lol wtf ? Quote Link to comment
zerow Posted February 16, 2010 Report Share Posted February 16, 2010 Alright So I can set the RPM on... friday ? lol and I need to go junkyarding for a alt bracket that looks like my S130 one, a lower mounting bolt for the alt, as my po only mounted w/ one, and then the little brackets and bolts that mount to the bottom of the engine and the front of the trans as I don't have those lol wtf ? I have had to learn the hard way to do what I can, when I can. As for the parts you need, try Milliken. I was there a week ago, not much in the way of other small L-series cars/trucks, but there were more than a handful of Z Cars. Hope that helps... Quote Link to comment
nbesheer Posted February 16, 2010 Author Report Share Posted February 16, 2010 Sweet I'll hit it up, these parts are 4 or 6 cyl parts so it really doesn't matter. Quote Link to comment
