P0werPlentySR20 Posted November 22, 2009 Report Share Posted November 22, 2009 ok so ive read through all the headlight break-downs on here and none are similar to mine so heres the thing. i have a 72 510 (2dr) lights worked fine for the first 2 days i had it then the lows/highs went out. all my other lights come on (interior, corners, blinkers etc.) i checked the headlight fuses and both checked out good...switch is still clicking when i pull it in the (on) position so im sure its not the switch... what else can i check? Quote Link to comment
DanielC Posted November 22, 2009 Report Share Posted November 22, 2009 Remember the 510 uses a relay to ground the headlights. Check for voltage at the headlights. The headlights have power applied all the time the headlight switch is on, and the relay completes the circuit to ground, allowing either the low or high beams to come on. Quote Link to comment
moparvwfreak Posted November 22, 2009 Report Share Posted November 22, 2009 just because the switch clicks, doesn't mean its working. after checking the relay i would check that your getting continuity throught he switch. if not, then your lights wont work. Quote Link to comment
Creepy Cruiser Posted November 23, 2009 Report Share Posted November 23, 2009 Try cleaning the relays under the hood. Just about ever 510 I've ever had, I've had to clean the relay contacts Here is another thread on it to check out. http://forum.ratsun.net/showthread.php?t=14921 (start at post #8 and down) Let us know if that works. Quote Link to comment
P0werPlentySR20 Posted November 24, 2009 Author Report Share Posted November 24, 2009 thanks a lot guys tomorrow i have the day off so i will try cleaning the relay contacts..and if that doesnt work then i will start using all the other suggestions Quote Link to comment
