sdsurf Posted November 21, 2009 Report Share Posted November 21, 2009 Anyone have one or know the nissan part number? It is the gasket attached to the firewall. Quote Link to comment
MikeRL411 Posted November 21, 2009 Report Share Posted November 21, 2009 If you can't get one and you just need to seal against engine compartment noise and smell, use a very little bit of low expansion foam in a can. Quote Link to comment
Pacific coast Datsun Posted November 21, 2009 Report Share Posted November 21, 2009 Mike did i give you that one i had awhile back? if so to install it right it involves removing the collum or,,,cut it on the top then open it up & slide it around the collum. They originally were atached to a metal surround. On Roberts truck we made one using a piece of sheet metal & used silicone to seal it to the firewall. Or, take an old mud flap & cut it out so its the same shape. Quote Link to comment
sdsurf Posted November 22, 2009 Author Report Share Posted November 22, 2009 Mike did i give you that one i had awhile back? if so to install it right it involves removing the collum or,,,cut it on the top then open it up & slide it around the collum. They originally were atached to a metal surround. On Roberts truck we made one using a piece of sheet metal & used silicone to seal it to the firewall. Or, take an old mud flap & cut it out so its the same shape. Yeah I got that one mark, Thanks a ton. I was just looking for a part number to order a new one down the line Quote Link to comment
sdsurf Posted November 25, 2009 Author Report Share Posted November 25, 2009 I looked all through the 521 parts manual and didn't find a number. There is one for the 520 but this won't work. Quote Link to comment
