mark427ci Posted November 12, 2009 Report Share Posted November 12, 2009 the thing I am trying to understand is the oxygen sensor wiring from the how to section. I have a sensor with one wire.... if I send power to it like the diagram shows, how does the signal get to the computer? Any help? Thanks Quote Link to comment
banzai510(hainz) Posted November 12, 2009 Report Share Posted November 12, 2009 PM "Icehouse" on this site hes the wire expert Quote Link to comment
b210in Posted November 17, 2009 Report Share Posted November 17, 2009 the thing I am trying to understand is the oxygen sensor wiring from the how to section. I have a sensor with one wire.... if I send power to it like the diagram shows, how does the signal get to the computer? Any help? Thanks follow the diaghram exactly. it will fire up on the first try. Quote Link to comment
sdsurf Posted December 6, 2009 Report Share Posted December 6, 2009 I need to see pics of this work! I have toyed with this idea for a while and I have never seen one in a 521. Please share!!! Quote Link to comment
datzenmike Posted December 6, 2009 Report Share Posted December 6, 2009 the thing I am trying to understand is the oxygen sensor wiring from the how to section. I have a sensor with one wire.... if I send power to it like the diagram shows, how does the signal get to the computer? Any help? Thanks Power flows from the battery through the ECU to the O2 sensor and to ground on the block. The ECU is then able to monitor how much power flowed through it and makes it's calculation on that. Quote Link to comment
