LenRobertson Posted October 14, 2009 Report Share Posted October 14, 2009 I've looked through back posts, but I can't find a link to the clutch sleeve dimensions for 225mm clutch. I found this page with the 200mm clutch sleeve chart:http://dimequarterly.tierranet.com/tech/clutch.replacement.html Isn't there a similar chart for 225mm? Thanks. Len Quote Link to comment
datzenmike Posted October 14, 2009 Report Share Posted October 14, 2009 (edited) What clutch pp are you needing it for Len? Edited October 14, 2009 by datzenmike Quote Link to comment
moparvwfreak Posted October 14, 2009 Report Share Posted October 14, 2009 sorry to hijack, buti am going to be using the 225mm clutch thats on my L20. should i also use that sleeve and TO bearing from the trans that was originally mounted to it? Quote Link to comment
datzenmike Posted October 14, 2009 Report Share Posted October 14, 2009 (edited) The the clutch release bearing holder/housing is matched to the pressure plate size and has nothing to do with the transmission behind it. The 225mm pressure plate is longer (taller?) from the flywheel surface to the diaphragm finger tips than a 200mm p/p, and so the 225mm bearing housing is slightly shorter in length than the 200mm housing. This keeps the clutch arm in the same position and same range of motion regardless of the different finger heights. A 240mm housing would be even shorter to compensate for the increased finger height of the 240mm p/p. Edited October 14, 2009 by datzenmike Quote Link to comment
LenRobertson Posted October 15, 2009 Author Report Share Posted October 15, 2009 The clutch I have is from a 280Z or ZX (I have the year written down somewhere, but of course can't find it right now). I'm going to put a dogleg behind it for now, and I strongly suspect the TO bearing sleeve will be the wrong length. I have a late 620 PU 5-speed, and I'm thinking that sleeve will work (didn't 620s use a 225mm clutch?). But I'd like to find the 225mm sleeve chart for future reference. I imagine I have a printout of the chart somewhere, if no one has the link. Len Quote Link to comment
