S@nt0s Posted November 10, 2009 Author Report Share Posted November 10, 2009 thanx boss, just trying to keep this section active.... Quote Link to comment
b210in Posted November 10, 2009 Report Share Posted November 10, 2009 what do you think it'll run? Quote Link to comment
S@nt0s Posted November 11, 2009 Author Report Share Posted November 11, 2009 i will not accept anything slower then a 10.40 in the 1/4 mile.... and thats on the slow side... all i want is sub 10s if she dips in the 9's sweet... but then ill build a bigger/longer chassis Quote Link to comment
S@nt0s Posted November 15, 2009 Author Report Share Posted November 15, 2009 did some cleaning up of the TB inlet on the intake manifold and made a block off plate for the air idle control valve and mounted it. opened up the ports on the turbo manifold and mounted then clocked the turbo... Quote Link to comment
S@nt0s Posted November 17, 2009 Author Report Share Posted November 17, 2009 cams, springs and sprocket came in.... Brian Crower 272 cams Brian Crower valve springs Tomei Sprocket Quote Link to comment
S@nt0s Posted November 20, 2009 Author Report Share Posted November 20, 2009 another drop by the truck... today i ran the feedline..... Quote Link to comment
S@nt0s Posted November 24, 2009 Author Report Share Posted November 24, 2009 another drop by the truck... new window track stripping for the doors.. sold my Turbonetics T04E turbo and upgraded.... Turbonetics T66 with anti-surge housing Quote Link to comment
S@nt0s Posted November 26, 2009 Author Report Share Posted November 26, 2009 more goodies to help Quote Link to comment
b210in Posted December 20, 2009 Report Share Posted December 20, 2009 where you at playa, got it runnin yet? Quote Link to comment
S@nt0s Posted December 22, 2009 Author Report Share Posted December 22, 2009 holidays set me back a bit but i got some things for her just havent posted. i worked on fabbing a radiator for it this pasted weekend and its installed. i need to pick up some aluminum for my IC piping to make next. fuel rail material came in as well. i will be mocking that up soon to weld the ends on and drill the injector ports. i say a month maybe 2 tops she will be at least running then tune it finally. still havent installed my cams. i just need to route my return fuel line and its all done. Quote Link to comment
b210in Posted December 22, 2009 Report Share Posted December 22, 2009 holidays set me back a bit but i got some things for her just havent posted.i worked on fabbing a radiator for it this pasted weekend and its installed. i need to pick up some aluminum for my IC piping to make next. fuel rail material came in as well. i will be mocking that up soon to weld the ends on and drill the injector ports. i say a month maybe 2 tops she will be at least running then tune it finally. still havent installed my cams. i just need to route my return fuel line and its all done. ok. i just wanted to make sure you weren't slackin. hey, i have some questions about my car, can i pm you? Quote Link to comment
ANM21977 Posted December 30, 2009 Report Share Posted December 30, 2009 I WOULD LOVE TO PURCHASE ONE OF THE TOP MOUNTED EXHAUST MANIFOLDS FOR A SR20DET S14 FOR MY 1971 2DR DATSUN 510. PLEASE PM ME SO WE CAN SET UP DELIVERY AND PAYMENT. i NEED ONE WITHOUT THE EXTERNAL WASTEGATE PORT. I HOPE TO HEAR FROM YOU SOON. Quote Link to comment
datzenmike Posted December 30, 2009 Report Share Posted December 30, 2009 cams, springs and sprocket came in.... Brian Crower 272 cams Brian Crower valve springs Tomei Sprocket What made you pick a 272 cam? Don't turbo motors usually run closer to stock duration? What are your thoughts on this? Quote Link to comment
S@nt0s Posted January 1, 2010 Author Report Share Posted January 1, 2010 What made you pick a 272 cam? Don't turbo motors usually run closer to stock duration? What are your thoughts on this? so low end power and response ya, but this car will be running over 6k rpm 99% of the time... once i get headwork done i will take her up to 10k if the power is there which it should with the T66 Quote Link to comment
