tlap Posted September 22, 2009 Report Share Posted September 22, 2009 I have read allot of posts concerning which oil to use in a manual trans. I see that GL4 is recommended in the manual. I just finished rebuilding my Dogleg 5 speed and I want to use a synthetic oil. The well known transmission parts supply company that I got all the parts from recommends using Dextron III in this trans. Has any one used ATF? I also see that some say to stay away from GL5 due to the synchro material. I found that Royal Purple Max Gear, states.... "Max-Gear Quote Link to comment
Duke Posted September 22, 2009 Report Share Posted September 22, 2009 I have started using Redline MTL recently. Before using it, downshifting into third produced a little grind if you didn't match the revs perfectly. This is no longer a problem after using Redline. I have heard similar stories from other people. Proof enough for me to continue to use this stuff. Quote Link to comment
ggzilla Posted September 22, 2009 Report Share Posted September 22, 2009 They recomended Dextron III ATF? I can't believe that would be good. ATF doesn't have a high shear protection does it? Newer manual gearboxes are designed for ATF. 90W GL4 as Nissan recommends works great in these old boxes, even smooths out old worn syncros a little bit. A thinner oil supposedly makes shift "easier" but may not protect the gears. Quote Link to comment
