DDD2017 Posted September 10, 2009 Report Share Posted September 10, 2009 hi guys ! im new to ratsun but not to datsuns. this is my first carb to efi swap and i have most of it squared away besides locating those damn Bosch 30/40 a 4 prong headlight fuses. am i correct with the specs??lol anyways ive tried Kragen , autozone with no luck . tomorrow ill try Napa auto parts , any suggestions ?:mellow: Quote Link to comment
jesusno2 Posted September 10, 2009 Report Share Posted September 10, 2009 Their just standard headlight relay's napa will have them maybe not "bosch brand" you should only need 30 amp relays for the electric fan and fuel pump the other one will be fine with 20 amp ones if avaliable. Quote Link to comment
datzenmike Posted September 10, 2009 Report Share Posted September 10, 2009 Go to the wreckers and look at the 720s. Just above the fuse box on driver's kick panel and directly above the pass kick panel. Also the early WD-21 Pathfinder under the hood on pass side fender. You can also get the holder for them and always get the mating plug with length of wire for splicing. Auto choke heater and inhibit relay is 4 or 5 wire, headlight relay is 3 wire. Quote Link to comment
inline4 Posted September 10, 2009 Report Share Posted September 10, 2009 hi guys ! im new to ratsun but not to datsuns. this is my first carb to efi swap and i have most of it squared away besides locating those damn Bosch 30/40 a 4 prong headlight fuses. am i correct with the specs??lol anyways ive tried Kragen , autozone with no luck . tomorrow ill try Napa auto parts , any suggestions ?:mellow: autozone has them. they are in the section where the switches are. Quote Link to comment
