hessianben Posted September 6, 2009 Report Share Posted September 6, 2009 (this was part of my build thread, but it may be easier to address here) attempting a swap from L16 & 4 speed to L20b & 5 speed new motor & trans were from a '79 620 KC going into a '71 521 and now the questions... the 4 speed has a flange on the output shaft The 5 speed has a sleeve Also, the 5 speed is longer and came with a different crossmember/mount setup the 4 speed crossmember/mount I'm assuming that I will need to use the 620 L20b driveshaft... It came from a kingcab, so it will be too long- will have to shorten it. Does anyone know if the regular cab 620 driveshaft will bolt up? carrier bearing in same location? also, has anyone else had to rig up a different mount setup? any tips are appreciated!!! what other driveshaft options am I looking at? thanks Quote Link to comment
datzenmike Posted September 6, 2009 Report Share Posted September 6, 2009 Use the L20B mmts. The front half of the later 620 two piece d/s should fit. Almost 100% sure it will have the same bearing location and should bolt to the 521 rear half at the U joint. Maybe the whole 620 d/s will swap right in??? If so be sure to replace all U joints. Tranny mount: On each in side of the 620 frame is a gusset that the tranny mount pate bolts to. Make, or cut these off and weld onto the 521 frame and now you can use all the 620 rear tranny mount hardware. Quote Link to comment
hessianben Posted September 7, 2009 Author Report Share Posted September 7, 2009 Use the L20B mmts. The front half of the later 620 two piece d/s should fit. Almost 100% sure it will have the same bearing location and should bolt to the 521 rear half at the U joint. Maybe the whole 620 d/s will swap right in??? If so be sure to replace all U joints. Tranny mount: On each in side of the 620 frame is a gusset that the tranny mount pate bolts to. Make, or cut these off and weld onto the 521 frame and now you can use all the 620 rear tranny mount hardware. Thanks Mike- I still have access to the old driveshaft from the L20b. hopefully i can use the front shaft and mate it to the the back of the 521 shaft...! As far as the old frame and tranny mount gussets, the truck went to the scrappers with them. I have the crossmember, but anything that was welded, stayed on it. Looks like I'll be modifying the 4spd mounts... fhew. Quote Link to comment
Pacific coast Datsun Posted September 8, 2009 Report Share Posted September 8, 2009 Ben the Z [i used a 83 280 ZX 5 speed]& 521 tranny mounts will swap over. I used the 521 trans. mount like the one you posted.. I ended up cutting about 2 inches out of the mount before rewelding it. I have pix of it i can post if need be. Quote Link to comment
hessianben Posted September 8, 2009 Author Report Share Posted September 8, 2009 Thanks Mark, looks like I'll be cutting the 521 mount... Omar (OC) said that me may be able to help with the welding, so that will help out hugely! now just need a drive shaft... Quote Link to comment
