moparvwfreak Posted August 30, 2009 Report Share Posted August 30, 2009 will the clutch and flywheel from my L16 bolt over to the L20??? i just replaced the clutch in February and cant afford to do another one right now. Quote Link to comment
datzenmike Posted August 30, 2009 Report Share Posted August 30, 2009 Flywheel won't. L16 is 5 bolt to crank and L20B is 6 bolt. The 200mm clutch from the L16 will fit the L20B flywheel only if it's from a car. Truck L20Bs were all 225mm. Quote Link to comment
moparvwfreak Posted August 30, 2009 Author Report Share Posted August 30, 2009 great, make that christmas before i get my truck going then. damnit! Quote Link to comment
datzenmike Posted August 30, 2009 Report Share Posted August 30, 2009 ANY car L20B would have the 200mm flywheel 610/710/A10/200sx even the '80-'81 200sx with the Z20E motor had them. Quote Link to comment
moparvwfreak Posted August 30, 2009 Author Report Share Posted August 30, 2009 so if i swap to a smaller flywheel, i should be able to use my newish clutch? that might work. got any??? :D Quote Link to comment
Cuts metal like mad Posted August 30, 2009 Report Share Posted August 30, 2009 I think Justin has most of a 240mm clutch set... Quote Link to comment
datzenmike Posted August 30, 2009 Report Share Posted August 30, 2009 If you have a new 200mm clutch and PP on your L16 motor it will bolt to the car L20B flywheel. Car L20B flywheels only use the 200mm clutch. If you find one be sure to measure across the contact surface. L flywheels come in 200mm (car), 225mm, and 240mm (truck).... this one is a 240mm. http://i138.photobucket.com/albums/q251/datzenmike/Tranny/flywheel240mmthree2Large.jpg[/img]"] Quote Link to comment
moparvwfreak Posted August 30, 2009 Author Report Share Posted August 30, 2009 cool. thats exactly what i am wanting then. i already put up a want add for it. Quote Link to comment
