SHADY280 Posted August 22, 2009 Report Share Posted August 22, 2009 hey guys im swapping my 75's front brakes for hardbody discs with beebani's control arms and was looking about. the 75 has t/c rods, and the 78/79 lower control arms dont have a spot for them, does this just mean i delete them? it looks to me like the later model control arms are mounted much more solid than the early ones. Quote Link to comment
yello620 Posted August 22, 2009 Report Share Posted August 22, 2009 The 78/79's use a different style TC rod. The mount to lower control at two of the lower ball joint bolts. Inner bolt at the front of the lower BJ and outer bolt at the rear of the BJ. Your stock TC rods will not work. Quote Link to comment
SHADY280 Posted August 22, 2009 Author Report Share Posted August 22, 2009 god dang, anybody got a set kicking around, or a picture so i can fab some up with heim ends? im still working on getting the torsion rods out. they jiggle, but dont come out, any thoughts on that one. Quote Link to comment
Bleach Posted August 22, 2009 Report Share Posted August 22, 2009 Got time? I could keep an eye out in the cheap yard around here. I may go within the next month. The frame mounts are even larger on the 78/79... but I think that your forward mounts will still work. Quote Link to comment
SHADY280 Posted August 23, 2009 Author Report Share Posted August 23, 2009 even larger?? wow, oh well, im at the mercy, i still have to swap the front suspention, trans and mount the seats and radio, cluster, tach, elec fan and elec fuel pump, as well as a 280zx alternator. i got some time id say. the truck can still move without those, just not very much. got any pix anyone incase i want to fab them. and how do the torsion bars come out, i got miune to jiggle, but they wont slide out towards the rear, am i doing it wrong? Quote Link to comment
datzenmike Posted August 23, 2009 Report Share Posted August 23, 2009 Originally Posted by Bleach View Post How to Re-index Torsion Bars in front of the middle cross member, you pull the boot forward to reveal the lock ring Work a thin screwdriver into the edge of the ring. It will be tight. I had to work the angle back and forth while occasionally tapping the back of the handle with a hammer Once you get under the ring, work it out slightly. Do not pull the screwdriver away or the ring will pop back on After you have worked it off part way, use some pliers to pull the ring off the rest of the way. Be sure to still keep the screwdriver under the lock ring. Tap the rear arm of that holds the adjuster bolt out of the crossmember. Hang onto the torsion bar Quote Link to comment
SHADY280 Posted August 23, 2009 Author Report Share Posted August 23, 2009 perfect, thx mike i didnt find that when i searched. i even typed just torsion in too. Quote Link to comment
SHADY280 Posted August 25, 2009 Author Report Share Posted August 25, 2009 i got them out, thx for the info, and i found pix of the t/c rod on glengemans swap in the how to section. to get the lower control arm off i had to cut one side and torch the rubber part of the bushing out, then cut the inner sleeve of the bushing to save the torsion bar bolt with the indexing head on it. good thing im not saving those lower arms and going to the later model ones. Quote Link to comment
