spiffinspudater Posted September 24, 2007 Report Share Posted September 24, 2007 HOW DO YOU GET THE DAMN GUAGE CLUSTER OUT!!!??? Ok, I know about the 3 screws. there are some bolts on the botom... the part I am getting hung up on is the darn Cigarette lighter! How do you unattach that. I tried turning, pulling, kicking, sawing... WTF do I have to do to get it unattached! EDIT: Sorry this is on a 1978 620 Pickup. Quote Link to comment
datsunaholic Posted September 24, 2007 Report Share Posted September 24, 2007 That's why most facias are destroyed. Most folks don't know how to remove it, or have too big of hands to reach it. You have to unscrew the cig lighter retainer from behind. It holds the cig lighter assembly to the METAL part of the dash. It surrounds the entire cig lighter, reverse bayonet style, and forms the ground connection. It isn't easy to reach- there's only 2 ways, through the radio hole or up from underneath (which means removing the ash tray bracket). Usually the retainer is corroded in place, so fingers won't get it... I use a pair of channellocks to get it started, then use fingers the rest of the way. Once you know how it's easy- I can get dash facias out in a couple minutes. Hardest part for me is getting the cluster wiring off the circuit board without breaking that. Small hands are a plus here. Expect many small cuts. Quote Link to comment
spiffinspudater Posted September 24, 2007 Author Report Share Posted September 24, 2007 Thanks! I got it out and am now working on my lights... I did however forget that I dont have electrical tape... SO, I get to wait till I get that to put it together and remount it all with my new gauge lights... Quote Link to comment
datzenmike Posted September 25, 2007 Report Share Posted September 25, 2007 Don't forget the LED turn signals!!! Quote Link to comment
spiffinspudater Posted September 25, 2007 Author Report Share Posted September 25, 2007 Don't forget the LED turn signals!!! Those will be later:P I will brb gona test the lights... Quote Link to comment
Steve - AF1 Racing Posted September 4, 2011 Report Share Posted September 4, 2011 That's why most facias are destroyed. Most folks don't know how to remove it, or have too big of hands to reach it. You have to unscrew the cig lighter retainer from behind. It holds the cig lighter assembly to the METAL part of the dash. It surrounds the entire cig lighter, reverse bayonet style, and forms the ground connection. It isn't easy to reach- there's only 2 ways, through the radio hole or up from underneath (which means removing the ash tray bracket). Usually the retainer is corroded in place, so fingers won't get it... I use a pair of channellocks to get it started, then use fingers the rest of the way. Once you know how it's easy- I can get dash facias out in a couple minutes. Hardest part for me is getting the cluster wiring off the circuit board without breaking that. Small hands are a plus here. Expect many small cuts. That was very helpful for me just now, thank you! Quote Link to comment
