ser240z Posted July 19, 2009 Report Share Posted July 19, 2009 Blew the fusible link on the 610 anybody got any solutions? Anybody know what the amperage rating is on that thing so I can just replace it with a newer fuse? Thanks Scott Quote Link to comment
datzenmike Posted July 19, 2009 Report Share Posted July 19, 2009 Nissan uses a color code. These are for Zcars but likely the same. Pink 30 amp Green 40 amps Red 50 amps Yellow 60 amps Black 80 amps Blue 100 amps Quote Link to comment
ggzilla Posted July 20, 2009 Report Share Posted July 20, 2009 Get a spare at Pull-a-part, or your local auto parts store. Quote Link to comment
ser240z Posted July 20, 2009 Author Report Share Posted July 20, 2009 Thanks for the reponses. datzenmike, I'm not sure what color it is. Kinda looks like a brownish, orangish, almost like rust. I found another site that said this color that is stated to be brown is actually supposed to be red. Can you confirm this? ggzilla, thanks. Not really a pick a part too close to me and I checked with the auto stores. Autozone was the only one that had it, special order and it runs $10. I was thinking about picking up a couple just in case, but thought that maybe I can convert it to a regular fuse, and make it a little easier if it ever blows again. Thanks Scott Quote Link to comment
ggzilla Posted July 20, 2009 Report Share Posted July 20, 2009 You can't use a fuse. The Fusible Link has special characteristics. You can use a fusible link from another car. I am using a ford mustang fusible line (wire) in my Datsun. Just a special piece of wire. Quote Link to comment
zerow Posted July 21, 2009 Report Share Posted July 21, 2009 (edited) The 610 uses two different colored wires - I will get the correct colors from the 1973 FSM tomorrow Or today...:rollseyes: Brown---0.3 sq. mm. (0.0005 sq. in.)-----Continuous Current = 11A-----Max current (fuse melts within 5 seconds) = Approx. 60A [Roughly translates to 22GA] Red-----0.85 sq. mm. (0.0013 sq. in.)----Continuous Current = 26A-----Max current (fuse melts within 5 seconds) = Approx. 250A [Roughly translates to 18GA] Hope this helps. Edited July 21, 2009 by zerow Quote Link to comment
datzenmike Posted July 21, 2009 Report Share Posted July 21, 2009 You can't use a fuse. The Fusible Link has special characteristics. You can use a fusible link from another car. I am using a ford mustang fusible line (wire) in my Datsun. Just a special piece of wire. It can sustain a current spike that would blow a fuse without it blowing. It acts like a slo-blow fuse and heats up slowly and melts usually within a few seconds. The outer Hypalon coating is designed to melt but not catch fire.... supposedly. It is there in case of a severe current draw such as in an accident where wires are crushed and grounded. Quote Link to comment
ser240z Posted July 22, 2009 Author Report Share Posted July 22, 2009 Thanks for the help everyone. I got some universal fusible link at Autozone, 16GA rated to 1.0 sq mm, but cut to length which was a little less than half ( was trying to match up to stock, about the same gauge and length), crimped it into the stock connectors, and plugged it back in. Worked great! I got my lights and everything working except the gauges. I can't figure that one out yet. I took the car for my first drive last night. Thanks Scott Quote Link to comment
