Dudeman Posted July 17, 2009 Report Share Posted July 17, 2009 So on the way to work today the truck started to run rough and was quite sluggish, and it was apparent that a cylinder was cutting out. On the way home I picked up a new set of plugs and plug wires just in case (the old ones were kind of nasty), and after I threw them on, no change. So I tested for spark and sure enough no. 3 wasn't getting any, though the other cylinders were. I've checked all my connections and they're good, and the next step is to get a new cap and rotor. Ignition is not exactly my area of expertise, so I'm wondering if there is anything else I should be looking at before convincing myself that a cap and rotor will solve my problems. Thanks for any help, Ian Quote Link to comment
datzenmike Posted July 17, 2009 Report Share Posted July 17, 2009 Sounds like the right thing to do. Not a big expense and if the wires were that bad the cap is likely ready to be changed anyway. Quote Link to comment
banzai510(hainz) Posted July 17, 2009 Report Share Posted July 17, 2009 swap the wire from #2 and move it to #3 since they be close to the same length. . menaing just use the wire dont change the wire order. did you see that there was no spark to the plug.????? Cjange plug otherwise maybe a lashpad fell off the Rocker Arm and its not exploding inside(firing off). Buy NGK wire set #NE64 and youll never have bad plug wires again Quote Link to comment
Dudeman Posted July 17, 2009 Author Report Share Posted July 17, 2009 Got a new rotor and cap and she fired right up! best the 620's run since i bought it. Its been a long battle, one thing after another kept failing on this truck, but it finally runs without flaw. Now I can get some HB front brakes and Isuzu rears. :D This forum and everyone on it have been an invaluable resource, thanks! Quote Link to comment
