novita1021 Posted June 19, 2009 Report Share Posted June 19, 2009 i cant seem to find any info on the Z22E...ive had it sitting for a while now and i still dont know where to start with it...i dont know the wiring or anything...ive googled and not alot of swap info come out just ppl who already have it or parts or frankenstien build..:confused::( Quote Link to comment
Phlebmaster Posted June 19, 2009 Report Share Posted June 19, 2009 do you have any pics of what you are starting with?? I am a visual kinda guy. :D Quote Link to comment
datsunaholic Posted June 19, 2009 Report Share Posted June 19, 2009 Would kind of help if you said what you were trying to do with it... put it in something, take it out of something, make it run, use it as an anchor, or what? Quote Link to comment
novita1021 Posted July 9, 2009 Author Report Share Posted July 9, 2009 well first i wanna make shure its good i dont wanna just put it in my 510 hopping it runs...i might need wiring help and maybe some swap tips from the ratsun..haha..dont know alot about this engine...read and heard that it drops right in..so sounds simple and its an upgrade over the l series ohh and well its efi..pix ill take some tomorrow after all this time i still have not photographed it..haha Quote Link to comment
datzenmike Posted July 9, 2009 Report Share Posted July 9, 2009 Only the L series motors 'drop in'. A Z20/22E with EFI won't 'drop in'. At the least you will need a Z series transmission so the engine sits upright in the engine bay. That's the big thing. You will also need a high pressure in-line fuel pump for the EFI system and some creative placement of the air flow meter, air pipes to the intake and the EFI wiring harness and ECU. Here's some home work reading on 200sx EFI wiring: http://datsun1200.com/modules/mediawiki/index.php?title=200SX_EFI http://www.dimequarterly.tierranet.com/articles/tech_efi.html You should know if this motor works when you buy it, other wise why bother? If you know that it runs, then it will run in a 510 with some work. Quote Link to comment
