cjr198car Posted June 10, 2009 Report Share Posted June 10, 2009 I made these numbers yesterday while tuning the VG NA and with N20. I was on a mustang dyno, these typically put down 10-15% less than a dynojet. Well on the nitrous with a .046 jet ("80" hp shot) @ 950 psi bottle pressure I layed down: 222 whp 314 wtq My setup is a stock VG30E, and im talking totally stock. stock plugs (stock gap) stock 200sx cast manifolds stock cams stock heads stock 200sx intake plenum stock injectors stock flywheel NOS dry kit with an adjustable bleed off "T" to adjust regulator fuel pressure TEC3 for ignition TEC3 for tuning Off the bottle I laid down: 140 whp (82 whp gain on the N20) 173 wtq (141 wtq gain on the N20) Fun stuff. Instead of doing cams, headers, cam gears, plenum spacer, and head work for 180-200 whp and 210-230 wtq (NA) Im going to just start putting together a turbo kit (I have experience with turbo cars). I want a solid 300 whp and 350 wtq. -cjr198car Quote Link to comment
banzai510(hainz) Posted June 10, 2009 Report Share Posted June 10, 2009 man I would be lucky if I had 90hp@wheel with my L16/sidedraft 40mm carbs!!!!!!!! Quote Link to comment
benzo Posted June 11, 2009 Report Share Posted June 11, 2009 that is nice. torque is sweet both NA and nitrous. real street ripper. got to see the graph. I bet it is very flat. It is kind of nice you went with a nice ecu and ignition control Quote Link to comment
onedayjake Posted June 11, 2009 Report Share Posted June 11, 2009 Nice numbers, we have a Mustang dyno at our shop and we call it the dream crusher for that very reason. Quote Link to comment
qwik510 Posted June 11, 2009 Report Share Posted June 11, 2009 Looks like a really clean install. Very Impressive numbers too. I sent you a PM. Check your inbox. Thanks, Quote Link to comment
cjr198car Posted June 11, 2009 Author Report Share Posted June 11, 2009 qwik did you get my pm? Quote Link to comment
cjr198car Posted June 11, 2009 Author Report Share Posted June 11, 2009 Benzo, The graph spikes with the nitrous. The hp stays in the low 200 whp till about 5500 rpm then falls off. The torque carries in the high 200-low 300 wtq till about 4500 rpm then falls off. This nitrous use is a perfect example of why you want more intake and exhaust flow. The engine is choking up on the plenum, exhaust manifolds, and cams. Like I said im probably not going to play around with anymore engine mods till a turbo. I now know when I go drag racing to shift at about 5500 rpms opposed to the 6000-6250 I was revving to (ill make more shifts, but Ill be in the sweet spot longer). Its a great street car, and on the juice its nasty. nothing like a 141 wtq hit at 3000 rpms. Thanks guys! -cjr198car Quote Link to comment
qwik510 Posted June 11, 2009 Report Share Posted June 11, 2009 qwik did you get my pm? Just got it and replied. Thanks. Quote Link to comment
benzo Posted June 12, 2009 Report Share Posted June 12, 2009 (edited) That is one thing I like about Nitrous. lots of fun and not very expensive to start off and makes things interesting. I make good hp on my Lseries but I do remember driving turbo or Nitrous motors and it was lots of fun. you have the all around package. clean car. strong motor. have fun. Oh one thing i noticed and correct me if I am wrong. I think I see the nitrous nozzle close to the the throttle body. I notice that when you move the nozzle closer toward the filter the nitrous is smoother and lets the mixture atomize better. I used to do Nitrous on Ford Probe V6's and it made a difference and also on Hondas with dry kits unless you switch to Wet system or direct port. Have you looked at hogging out the throttle body and extrude honing the intake man. Edited June 12, 2009 by benzo Quote Link to comment
cjr198car Posted June 12, 2009 Author Report Share Posted June 12, 2009 Benzo, Thanks! I havent played with distance from the throttle body (I can see what you're saying on placement). I have it placed about three to four inches from the throttle body (this was reccommended by nitrous supply), if I get ambitious ill play around with distances. The throttle body is restrictive, but I havent invested anytime into looking for a larger replacement (definitely on the to do list) I just purchased an extra upper plenum gasket and will be making a 3/4 inch spacer (using the gasket as my guide) to increase plenum volume. The other main restrictions are the 200sx cast manifolds and cams, but like I said it will be a turbo motor next year so Im not worried about the manifolds right now. -cjr198car Quote Link to comment
Bleach Posted June 12, 2009 Report Share Posted June 12, 2009 140whp is pretty good for a stock engine. But, its not factory fuel management. What do you use? I dont' see the MAS :) Quote Link to comment
510six Posted June 12, 2009 Report Share Posted June 12, 2009 (edited) Nitrous can be very entertaining, I ran a 120 rwh shot on an all JY parts 3 liter L series stroker. My 510 ran a best of 12.55 @110 with a 120 rwh shot . The car had a seriously resitrictive Bosch CIS injection system, changing to MAP based SDS injection rather than the CIS setup netted 35 rwh and .3 at the strip. The same shot on a mild (BUILT) 3 liter turbo motor turned into a over 200 rwh shot and netted a best E.T. of 10.96 @127. A friend with a bone stock 86 z31et ran 12.7 @111 using a 100 rwh N20 shot . The only mods to the motor were a KA24 TB and an exhaust cutout right after the stock downpipe. The car also had a welded R200 and E.T. Street tires , taking a thousand pounds of weight out of a similar setup should yield a VERY fast 510. Edited June 12, 2009 by 510six Quote Link to comment
cjr198car Posted June 12, 2009 Author Report Share Posted June 12, 2009 (edited) Bleach, Stock fuel. TEC3 engine management (this system uses a map sensor instead of a maf). 510six, Thats awesome! I appreciate the help on the rear end setup. With the right tires Ill be looking for high twelves. Here is a video of me doing 8.5's in the 1/8th with a .042 jet (im running a .046 jet now). (no spray until I hooked, 2.1 60 foot on my 205 falken 512 street tires) -cjr198car (colton) Edited June 12, 2009 by cjr198car Quote Link to comment
510six Posted June 12, 2009 Report Share Posted June 12, 2009 Bleach, Stock fuel. TEC3 engine management (this system uses a map sensor instead of a maf). 510six, Thats awesome! I appreciate the help on the rear end setup. With the right tires Ill be looking for high twelves. Here is a video of me doing 8.5's in the 1/8th with a .042 jet (im running a .046 jet now). (no spray until I hooked, 2.1 60 foot on my 205 falken 512 street tires) -cjr198car (colton) With 222 rwh and some sticky tires low 12's should be very possible, when I ran 12.55 it was with 256 rwh and 288 fpt . With a stock turbo VG30et running 9-10psi and a 80 rwh shot (which will probably turn into a 120rwh shot) , I see testing the limits of the stock components will be the problem. Quote Link to comment
