SRSANDS Posted May 27, 2009 Report Share Posted May 27, 2009 Well this is going to be a wierd question but is there any bolts on the starter or trans that could be too long othat could rub on the flywheel or something? Or could the starter be in too tight or something? When I crank the car before it finally fires it just sounds like its coughing and there is resistance. It drains the battery quick if it doesnt start quickly. After it fires it seem to run pretty good without resistance. I havent had a L motor before so I dont know what to expect. Also, the exhaust is cut just below my feet underneath so???? I dunno I just dont wanna mess anything up it doesnt sound free when cranking.......:confused: Is there adjustment in the starter? Quote Link to comment
sssr20det510 Posted May 27, 2009 Report Share Posted May 27, 2009 check make sure you have a good battery first. also you could have a bad starter without hearing it its hard to say Quote Link to comment
SRSANDS Posted May 27, 2009 Author Report Share Posted May 27, 2009 Whats a bad starter sound like, its not a grinding noise its just wierd noise always....not a smooth cranking but a erun erun erun noise then it fires up maybe a weak battery....shouldnt be its a yellow top optima Quote Link to comment
Cuts metal like mad Posted May 27, 2009 Report Share Posted May 27, 2009 doesn't matter what type of battery it is... if its bad its bad. Sounds like a bad battery. Besides optima's are known for being defective... and if they sit too long unused they shit the bed and won't take a charge. Quote Link to comment
sssr20det510 Posted May 27, 2009 Report Share Posted May 27, 2009 doesn't matter what type of battery it is... if its bad its bad. Sounds like a bad battery. Besides optima's are known for being defective... and if they sit too long unused they shit the bed and won't take a charge. +1 Quote Link to comment
zed Posted May 27, 2009 Report Share Posted May 27, 2009 Maybe take the starter out - it's only two bolts - and have a look at the starter drive teeth and the flywheel teeth? Are the connections on the starter, solenoid and earths good? Quote Link to comment
SRSANDS Posted May 27, 2009 Author Report Share Posted May 27, 2009 I will check it out....probly just a week battery in combo with a carb (not use to it) and no exhaust.....:o Quote Link to comment
datzenmike Posted May 27, 2009 Report Share Posted May 27, 2009 Well this is going to be a wierd question but is there any bolts on the starter or trans that could be too long othat could rub on the flywheel or something? Or could the starter be in too tight or something? When I crank the car before it finally fires it just sounds like its coughing and there is resistance. It drains the battery quick if it doesnt start quickly. After it fires it seem to run pretty good without resistance. I havent had a L motor before so I dont know what to expect. Also, the exhaust is cut just below my feet underneath so???? I dunno I just dont wanna mess anything up it doesnt sound free when cranking.......:confused: Is there adjustment in the starter? The through bolts can't hit the flywheel no matter how long. There is no adjustment for the starter. First be sure the starter is bolted in securely. There should be a thin metal spacer sandwiched between the engine block and the transmission. Easily seen specially if the starter is removed. If the flywheel has been off and this spacer not put back on when assembled, the starter will be mounted too close to the flywheel teeth. Remove the two battery terminals and clean them. Don't put back on yet. Check that the positive terminal from the battery is clean and tight on the starter terminal. Check that the negative cable is clean and tight where it's bolted to the head. Now connect the battery cables to the battery and tighten. Be sure the battery is charged and try to start. If still not working connect jumper cables from another car to your battery terminals... if that fixes it then either your battery is not charged or not capable of taking a charge. If STILL not working then maybe the starter is no good. These checks are easy and cost nothing to do and should prevent you replacing something not needed. Quote Link to comment
LCDC Posted May 27, 2009 Report Share Posted May 27, 2009 The through bolts can't hit the flywheel no matter how long.There is no adjustment for the starter. First be sure the starter is bolted in securely. There should be a thin metal spacer sandwiched between the engine block and the transmission. Easily seen specially if the starter is removed. If the flywheel has been off and this spacer not put back on when assembled, the starter will be mounted too close to the flywheel teeth. Remove the two battery terminals and clean them. Don't put back on yet. Check that the positive terminal from the battery is clean and tight on the starter terminal. Check that the negative cable is clean and tight where it's bolted to the head. Now connect the battery cables to the battery and tighten. Be sure the battery is charged and try to start. If still not working connect jumper cables from another car to your battery terminals... if that fixes it then either your battery is not charged or not capable of taking a charge. If STILL not working then maybe the starter is no good. These checks are easy and cost nothing to do and should prevent you replacing something not needed. When is the book gonna be published?:D Quote Link to comment
5tinguy Posted May 27, 2009 Report Share Posted May 27, 2009 Is your ignition timing too far ahead? Turn your distributor back and see if noise goes away and motor fires up easier. Quote Link to comment
Datsun fan Posted June 21, 2009 Report Share Posted June 21, 2009 I bet it is definitly a fucked up battery or alternator , test alt volts & amps & if you found something bad then you have just saved another battery from being fucked by bad alt . Faulty battery will show symptom like you have & even acceptable cranking speed can't start engine , maybe faulty and weak enough to not make sparks in the plugs lol . Quote Link to comment
