troyt Posted May 20, 2009 Report Share Posted May 20, 2009 I'm building a long rod L20 for the race Wagoon (L20b +2mm block, L20b crank, 6" Z20e rods, Z22e pistons). I'm using a V9182 head, and am looking for about a 12:1 CR. Has anyone found a source for higher compression Z22e pistons? I've had Ross and Venolia build custom ones before for L24s, but I was wondering if there are any off-the-shelf ones out there. Thanks Quote Link to comment
hang_510 Posted May 20, 2009 Report Share Posted May 20, 2009 not likely on any shelves anymore... i have a new set of domed arias @ 88mm avail. est 12:1 stock L20b pin height. never used, w/ pins & rings Quote Link to comment
69FJWagon Posted May 20, 2009 Report Share Posted May 20, 2009 I'm building a long rod L20 for the race Wagoon (L20b +2mm block, L20b crank, 6" Z20e rods, Z22e pistons). I'm using a V9182 head, and am looking for about a 12:1 CR. Has anyone found a source for higher compression Z22e pistons? I've had Ross and Venolia build custom ones before for L24s, but I was wondering if there are any off-the-shelf ones out there.Thanks call Troy Ermish he might be able to help he is right across the bay from you in fremont and has a shop full of vintage B sedan cars you would probably be interested in checking out, click the link in my sig to see his site Clayton Quote Link to comment
zed Posted May 21, 2009 Report Share Posted May 21, 2009 (edited) 12:1 CR? I just finished a L18 rebuild with 11.25:1 - and everyone warned me it will knock on pump gas, and my headgaskets will not last. With 12:1 are you not going to have detonation/knocking or pre-ignition? Especially with dome pistons - the flame has longer to travel than with flat tops. What is your squish band - the clearance between head and piston at TDC? Edited May 21, 2009 by zed Quote Link to comment
troyt Posted May 21, 2009 Author Report Share Posted May 21, 2009 "race wagon" It will never see anything less than 100 octane, most tracks these days just sell 100 unleaded and 110 leaded. 12:1 works down to 100 octane with properly maintained cooling and ignition systems. 14:1 will work with 110 again with everything set up correctly. Modern electronically controlled cars can run 93 octane with 11:1, but Datsuns don't like much more than 10:1 on 93 octane pump gas. I raced my ITS 240Z with 9.5:1 CR for years on 92 octane pump gas, just mixed a gallon of leaded race gas in on hot wknds to help with pre-ignition (35 degrees adv on a MSD). Of course this is just my $.02 worth, I'm sure others aren't as conservative as I am with their motors. Quote Link to comment
datzenmike Posted May 22, 2009 Report Share Posted May 22, 2009 i have a new set of domed arias @ 88mm avail. est 12:1 stock L20b pin height. Unfortunately they wont work on the 152.5mm Z20E rods. I'm building a long rod L20 for the race Wagoon (L20b +2mm block, L20b crank, 6" Z20e rods, Z22e pistons). I'm using a V9182 head, and am looking for about a 12:1 CR. Has anyone found a source for higher compression Z22e pistons? I've had Ross and Venolia build custom ones before for L24s, but I was wondering if there are any off-the-shelf ones out there.Thanks Sure substitute stock VG30E pistons. 87mm bore and same pin height as the Z20E pistons used on the 6" rods. It has a 1cc dish. So.... 87mm bore 86mm stroke (2044cc motor) with 152.5mm rods, 31.75 pin height VG30E pistons with 1cc 'dish', 219 head and a minus .2mm deck height ... works out to 11.159 compression ratio. This assumes the 219 head has a volume of 41cc and has not been milled. IF it has been milled, or you plan to mill it. Reducing the peanut chamber volume down to 36.7cc will give you your 12.10 compression. I don't know the area of a closed chamber combustion chamber but an open chamber head that is milled 1mm will reduce the combustion chamber volume by 5.9cc. 1mm off a closed chamber head would be less than that and probably very close to what you want. Quote Link to comment
zed Posted May 23, 2009 Report Share Posted May 23, 2009 I cc'd my V912 head after having it skimmed .020" - was 38cc. Didn't cc it before though... Quote Link to comment
