Guest DatsuNoob Posted May 20, 2009 Report Share Posted May 20, 2009 Does anyone know which pilot bearing or bushing to use, when doing the KA to ZX 5spd swap? How about the clutch sleeve? I've got an '83 ZX 5spd with Z24 bell, ready to go on as soon as I figure it all out. Thanks Quote Link to comment
datzenmike Posted May 20, 2009 Report Share Posted May 20, 2009 (edited) Does anyone know which pilot bearing or bushing to use, when doing the KA to ZX 5spd swap? How about the clutch sleeve? I've got an '83 ZX 5spd with Z24 bell, ready to go on as soon as I figure it all out. Thanks I assume that's an '83 non-turbo 5 spd that you are putting a Z24 front case on so you can use with a KA24E motor? You know that you will need to remove the 56mm countershaft bearing and press on a 62mm to fit the Z24 case? Also the 1st/2nd shift rod hole is too big?Use the pilot bushing for the motor you are using. All L, Z and KA24E, VG30E up to at least '90 used the same pilot bushing. Clutch sleeve is matched to the clutch size used, not the tranny. Edited May 20, 2009 by datzenmike Quote Link to comment
BEEBANI Posted May 20, 2009 Report Share Posted May 20, 2009 I used all the zx tranny parts on mine. Although the ka clutch was already on the motor when I got it. Quote Link to comment
Guest DatsuNoob Posted May 20, 2009 Report Share Posted May 20, 2009 (edited) Yeah, doing the KA24de swap, using the Z24 bell and 83 zx non turbo trans. The DE looks to be the same as the Z24 bell as far hole locations and dowel pins, I'm confident it'll work out fine. Also, what about the T.O. bearing, do you know if the KA and ZX are the same? Thanks for the info, I'll be getting the rest of the stuff I need very soon. Jason, did your ZX slave on the Z24 bell work out? Edited May 20, 2009 by DatsuNoob Quote Link to comment
Guest DatsuNoob Posted May 21, 2009 Report Share Posted May 21, 2009 I assume that's an '83 non-turbo 5 spd that you are putting a Z24 front case on so you can use with a KA24E motor? You know that you will need to remove the 56mm countershaft bearing and press on a 62mm to fit the Z24 case? Also the 1st/2nd shift rod hole is too big?Use the pilot bushing for the motor you are using. All L, Z and KA24E, VG30E up to at least '90 used the same pilot bushing. Clutch sleeve is matched to the clutch size used, not the tranny. I guess what I meant to ask earlier about the pilot, is I'm using a 98 frontier 2.4de, 240sx aluminum flywheel, zx trans. So this being a total mutt setup,:lol: and the pilot bearing sits behind the flywheel, do I get the one that matches the frontier motor, or do I get the one for a 240sx since I'm using that flywheel, or does it matter? Quote Link to comment
datzenmike Posted May 21, 2009 Report Share Posted May 21, 2009 Pilot bushing for in the end of the crankshaft... get the one for the KA24DE. As long as the '83 5spd was used with a 240mm flywheel the release bearing sleeve/housing should work. Quote Link to comment
Guest DatsuNoob Posted May 21, 2009 Report Share Posted May 21, 2009 (edited) OK, frontier bushing it is. I opened the input shaft cover a few minutes ago. The neck that slips into the sleeve was broken, and upon closer inspection I found that the shift rod holes are in fact larger than the ZX bell, as for the countershaft bearing on the trans getting used, I got 2.201" for an O.D. on the bearing. Not sure what that equates to in the metric world, hopefully it equals less work :lol: I still cant identify exactly what model trans I have. There's a #3 stamped on the driver's side, not sure if that helps. Where should I be looking for an indication. Edited May 21, 2009 by DatsuNoob Quote Link to comment
Cuts metal like mad Posted May 21, 2009 Report Share Posted May 21, 2009 told you... BUSHING... :fu: Quote Link to comment
Guest DatsuNoob Posted May 21, 2009 Report Share Posted May 21, 2009 Answered my own question on the measurement. It is in fact a 56mm bearing I have. This is a useful website for conversions I found, maybe someone else can use it. http://www.alcula.com/convert.php?cat=length&from=inch&to=millimeter Quote Link to comment
datzenmike Posted May 21, 2009 Report Share Posted May 21, 2009 OK, frontier bushing it is. I opened the input shaft cover a few minutes ago. The neck that slips into the sleeve was broken, and upon closer inspection I found that the shift rod holes are in fact larger than the ZX bell, as for the countershaft bearing on the trans getting used, I got 2.201" for an O.D. on the bearing. Not sure what that equates to in the metric world, hopefully it equals less work :lol: I still cant identify exactly what model trans I have. There's a #3 stamped on the driver's side, not sure if that helps. Where should I be looking for an indication. Measure the counter shaft hole in the Z bell. Likely it's 62mm so order a new counter bearing in that size and swap it. The 56mm counter bearing is subject to a lot of stress and will wear out and start growling. The larger 62mm one is a nice up grade. As for the shifter rod, only the top 1st/2nd should be the larger hole in the Z bell. What you need is a 1mm sleeve in the hole so it supports the 14mm rod in your zx tranny. Quote Link to comment
Guest DatsuNoob Posted May 21, 2009 Report Share Posted May 21, 2009 Cool, doesnt sound too bad. About those sleeves... they're readily available at machine shops? Seem like they'd be easy to install. So my plan is to go get the 720 countershaft bearing, then back to the jy for the input cover and shim (since they're bigger now). Thanks for all the great info on this, I'm real excited to get started. Too bad I dont have a camera :mad: Quote Link to comment
Guest DatsuNoob Posted June 3, 2009 Report Share Posted June 3, 2009 Got the bell swap done today, and am happy to say the shift rod holes in the bell housings of an 85 720 5 spd and an 83 zx 5spd are the same size!:D STOKED!:D Did the countershaft bearing and put it all together right before heading out for work. I'll post the nissan part number for that bearing in case someone else needs it for future reference. Quote Link to comment
Cuts metal like mad Posted June 3, 2009 Report Share Posted June 3, 2009 :thumbsup: Quote Link to comment
Guest DatsuNoob Posted June 4, 2009 Report Share Posted June 4, 2009 Nissan part number 32219-V5260, 62mm countershaft bearing is the one to get. Quote Link to comment
