sdsurf Posted May 5, 2009 Report Share Posted May 5, 2009 The center link in my truck is bent due to the PO trying to install a napz without using the proper pan. I have an extra one but I want the Ratsun experts opinions on how to remove and replace. Help please!! Quote Link to comment
Pacific coast Datsun Posted May 5, 2009 Report Share Posted May 5, 2009 Just a matter of unbolting the 4 bolts holding it on,,believe they are 17MM [been awhile since i was under a 521] Quote Link to comment
datzenmike Posted May 5, 2009 Report Share Posted May 5, 2009 I seem to remember something about not really needing it. It was a discussion on NWDE about the front of the torsion bars mounts. Datsunaholic do you remember this? Quote Link to comment
sdsurf Posted May 6, 2009 Author Report Share Posted May 6, 2009 I seem to remember something about not really needing it. It was a discussion on NWDE about the front of the torsion bars mounts. Datsunaholic do you remember this? isn't it fairly important for the steering? Quote Link to comment
datzenmike Posted May 6, 2009 Report Share Posted May 6, 2009 If you mean the steering cross rod then ... yes. I thought you meant the brace between the two lower control arms. PCD mentions 4 17mm bolts holding it on... I can see it being modified to give pan clearance but what idiot would bend or fuck with steering????? answer.. The PO!!!:blink: Quote Link to comment
sdsurf Posted May 6, 2009 Author Report Share Posted May 6, 2009 If you mean the steering cross rod then ... yes. I thought you meant the brace between the two lower control arms. PCD mentions 4 17mm bolts holding it on... I can see it being modified to give pan clearance but what idiot would bend or fuck with steering????? answer.. The PO!!!:blink: exactly. Thats why I want to know the ins and outs of removing and installing tie rod ends. Quote Link to comment
sdsurf Posted May 14, 2009 Author Report Share Posted May 14, 2009 Ok I got the new tie rod ends. Anyone replaced these? Do they screw on the bar til tight or do I need to get a proper length from the old and set it at that? Quote Link to comment
sdsurf Posted May 18, 2009 Author Report Share Posted May 18, 2009 done and done... Quote Link to comment
