jodaddy Posted May 3, 2009 Report Share Posted May 3, 2009 Hit the brakes and the right turn signal indicator comes on along with the dash lights. Turn the lights on and the right side tail lights go out when I hit the brake pedal. front right turn signal blinks the marker socket. turn the lights on and there is no right turn signal. I know it sounds confusing because it is! Please help. thanks, Joe Quote Link to comment
datzenmike Posted May 3, 2009 Report Share Posted May 3, 2009 (edited) Just a guess... check the front right signal bulb and the rear 2 filament bulb for brake and running light on the right side. The filament has broken and the loose end has flopped around and welded itself to the other filament. I think. Edited May 3, 2009 by datzenmike Quote Link to comment
jodaddy Posted May 3, 2009 Author Report Share Posted May 3, 2009 I wish it was that. all new bulbs. Quote Link to comment
yello620 Posted May 3, 2009 Report Share Posted May 3, 2009 Any chance that a dual filament bulb was installed where it should have been a single filament. This will cause weird feedback in the systems too. Quote Link to comment
moparvwfreak Posted May 3, 2009 Report Share Posted May 3, 2009 check your grounds!!!!!!! i know that i had something similar happen to a VW and the ground for that light was bad. Quote Link to comment
LCDC Posted May 3, 2009 Report Share Posted May 3, 2009 check your fuses and make sure there isn't a wrench fused to the wiring harness Quote Link to comment
jodaddy Posted May 3, 2009 Author Report Share Posted May 3, 2009 where are the grounds attached? Each bulb has a ground wire and they all tie together and go back into the harness. What is the best way to clean out the sockets? I tried to scrape them with a jeweler's flathead but that didn't work too well. thanks for all your replies, Joe Quote Link to comment
datzenmike Posted May 3, 2009 Report Share Posted May 3, 2009 Although there is a ground return wire on the rear harness, there is also a small black wire in the general area of the license plate that is bolted to the underside of the box between the bumper and the spare. Quote Link to comment
yello620 Posted May 4, 2009 Report Share Posted May 4, 2009 the ground for the headlights and front signals is on the core support near the battery. Quote Link to comment
jodaddy Posted May 4, 2009 Author Report Share Posted May 4, 2009 You mean the ground under the battery where the washer fluid leaks. Have to move that one over a little. Thanks guys I have been slowly making progress. A few more clean grounds and connections and 1 new bulb holder and I just might be in business. Joe Quote Link to comment
