maximo Posted April 30, 2009 Report Share Posted April 30, 2009 Hey guys, I'm almost ready to throw my 3236 on my L20B but I'm a little bit confuse with the Throttle Lever Assembly, does anybody has pictures of their set up. I'm using the original L20B intake manifold, so if you have some pictures It will help me a lot thanx. Quote Link to comment
banzai510(hainz) Posted April 30, 2009 Report Share Posted April 30, 2009 stock cable linkage part it will bolt up to the weber DGV from the stock carb.You might have to put washers as spacers so the cable fits nicely into the groove so its a nice transition so the cable dont wear prematurely. if you have a new kit it will come with a niclad plated calbe holder that will bolt up to the carb. if you dont have this you will have to oblong the holes as the weber the bolt spacing is BIGGER anf the stock cable holder will not fit ovee the stud spacing. Youll figure this out. Quote Link to comment
maximo Posted April 30, 2009 Author Report Share Posted April 30, 2009 Thanx Banzai, but do you have any pictures of the throttle lever assembly already installed. Quote Link to comment
jrock4224 Posted May 4, 2009 Report Share Posted May 4, 2009 they sell a braket kit to adapt the cable bought one with my base plate adapter.....works good i will try and remember to take a pic next time im near my truck....been busy tryin to diagnose a whistling weber... Bracket came out of yakima was here in one day off ebay.....i'll see if i can find the link for you.... Quote Link to comment
banzai510(hainz) Posted May 4, 2009 Report Share Posted May 4, 2009 maybe J rock has photos as I dont of the stock cable linkage on back of weber DGV(photo) Cant take one either as I dont have a digitalcamera Quote Link to comment
jrock4224 Posted May 4, 2009 Report Share Posted May 4, 2009 http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWNX:IT&item=330325978028 heres the auction i won ..........i dont see it relisted but i bet if you contact the seller he can have one to you.... Quote Link to comment
