moparvwfreak Posted April 29, 2009 Report Share Posted April 29, 2009 the 78 is leaking BAD out of the steering box. how hard is it to R&R it?? i really need to reseal it bad. has anyone had one of these boxes crack?? Quote Link to comment
moparvwfreak Posted May 12, 2009 Author Report Share Posted May 12, 2009 anyoone???? Quote Link to comment
datzenmike Posted May 12, 2009 Report Share Posted May 12, 2009 Yes I had one apart. (shudder) Is it leaking down at the bottom where the pitman are splines on? Quote Link to comment
datsunaholic Posted May 12, 2009 Report Share Posted May 12, 2009 I've pulled one out. It's a pain, as you have to take the whole steering column out at the same time. I managed to get one out with the engine still in by pulling the radiator and grille and going out the front, but I didn't much care what I did to the core support as I was doing a cab swap. Quote Link to comment
dat u racing Posted May 13, 2009 Report Share Posted May 13, 2009 I've also droped them out the bottom,and pulled thru the top, remove cover plate on firewall this will give more room and good luck getting pitman off !! I've change many and just put another one in. Quote Link to comment
datzenmike Posted May 13, 2009 Report Share Posted May 13, 2009 If leaking just above the pitman arm it's a bad sector shaft seal, Nissan pt.# 48137 36700. Can be replaced in the truck but the pitman arm must come off. Leave the steering linkages attached to the other end of the arm. Quote Link to comment
moparvwfreak Posted May 13, 2009 Author Report Share Posted May 13, 2009 its leaking not only at the pitman arm but at the point the column goes into the box itsself. what a pita. thanks for the parts # mike! Quote Link to comment
datzenmike Posted May 13, 2009 Report Share Posted May 13, 2009 Odd... do you have the proper oil in it, no additives? Quote Link to comment
moparvwfreak Posted May 13, 2009 Author Report Share Posted May 13, 2009 no additives. amd i assume the proper oil. my FSM states GL4. thats what i filled it with. but by now it has most likely leaked out. Quote Link to comment
