Skib Posted April 5, 2009 Report Share Posted April 5, 2009 The swap is almost done but I still have a few mystery wires (81' harness) Iv been looking threw old threads on hybrid for a few days and found some really good info but mine don't seem to mach up to a lot of the descriptions Iv read and reading manual diagrams is making my head hurt :( what are they? and do I need them? first two plugs: brown is something for FI? what dose it plug to? white...no clue? this plug is down by my ECU: possible ignitor plug in the wrong place? (just based on the looks of the plug) speaking of ignitor plug, is it part of the engine harness? because I don't seem to have one and it doesn't look like anything been cut off there wiring erks me sometimes :mad: Quote Link to comment
datzenmike Posted April 5, 2009 Report Share Posted April 5, 2009 This could be for the clutch or brake pedals. Maybe for the driver's door switch for interior light/door ajar buzzer? Courtesy under dash lights? The brown one is most likely for a relay, may clip to the fuse box if near. EFI relays are likely under the hood. Where are these plugs located?? Quote Link to comment
Skib Posted April 5, 2009 Author Report Share Posted April 5, 2009 The brown one is most likely for a relay, may clip to the fuse box if near. EFI relays are likely under the hood. Where are these plugs located?? there both on the pass side of the harness coming with the fuseable links box, knock sensor, and head temp sensor Quote Link to comment
City Hunter Posted April 6, 2009 Report Share Posted April 6, 2009 does the z drive the fuel pump off the engine harness? the white looks like a body harness plug like something going from the engine harness to the main harness. So possible it has things like water temp, oil pressure etc.. that goes to gauges. This is just a guess though. Quote Link to comment
Skib Posted April 6, 2009 Author Report Share Posted April 6, 2009 :D got it figured out. the brown one was an FI relay, the white goes to the body harness and there a few wires i need to splice from it into mine and the little white one dose nothing lol Quote Link to comment
240ADAM Posted April 7, 2009 Report Share Posted April 7, 2009 I will be in the same boat in a few days, i just yanked the stock one out out of my 75 and the are a hell of alot more wires under there than a 240. I have a turbo car still sitting here, the harness is already out but if i can look at something let me know. Your about a week ahead of me on your swap so i'll probly be asking you questions. Later! Quote Link to comment
City Hunter Posted April 7, 2009 Report Share Posted April 7, 2009 damn that was a good guess on the white one :D Quote Link to comment
